Iām not sure why the push notification is not working. but when I disable the servo part, the push notification is working just fine. Hope you can help. Thanks in advance!
Below is my code.
#define BLYNK_PRINT SwSerial
SoftwareSerial DebugSerial(10, 11); // RX, TX
#include <Servo.h>
char auth[] = "8f11761774984fbd805ac7b40aefb1cd";
void notifyOnButtonPress()
int isButtonPressed = !digitalRead(2);
if (isButtonPressed)
SwSerial.println("Button is pressed.");
// turn LED on:
digitalWrite(LED_BUILTIN, HIGH);
// turn LED off:
digitalWrite(LED_BUILTIN, LOW);
// Note:
// We allow 1 notification per 15 seconds for now.
Blynk.notify("Someone just press your doorbell!");
Servo servo; //the problem start from here
//if I disable this code or change V1 to D13
BLYNK_WRITE(V1) //the programme will run just fine
int pos = param.asInt();
if (pos==0)
servo.write(0);
Serial.println("Open");
else if (pos==1)
servo.write(180);
Serial.println(pos);
} //but this servo won't work
SwSerial.begin(9600);
//Do not read or write this serial manually in your sketch
Blynk.begin(Serial, auth);
// Setup notification button on pin 2
pinMode(2, INPUT_PULLUP);
// Attach pin 2 interrupt to our handler
attachInterrupt(digitalPinToInterrupt(2), notifyOnButtonPress, CHANGE);
//for LED
pinMode(LED_BUILTIN, OUTPUT);
servo.attach(9);
