the problem was arduino mega.
the problem in repeater , my project is offline …
change arduino mega, change ethernet shield , but the same problem …connect , disconnect…
Pete
ok
i have test with a sketch test and my lan is perfect…
Then the problem is the sketch you’re running when you get the disconnections.
not function with nobody sketch
connect and disconnect
in serial monitor
[12030] Using static IP
[13592] IP:192.168.188.98
[13592]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Mega
[13715] Connecting to blynk-cloud.com:8080
[28788] Connecting to blynk-cloud.com:8080
[31979] Login timeout
[33979] Connecting to blynk-cloud.com:8080
[49008] Connecting to blynk-cloud.com:8080
And which sketch are you running to produce this result?
