My physical button not working if not connected wifi
#1
#include "Adafruit_NeoPixel.h"
#include <DHT.h>
char auth[] = "";
char ssid[] = "cosmote";
char pass[] = "25802580";
char server[] ="192.168.1.10";
// Set your LED and physical button pins here
#define btnPin  D3
#define ledPin  D1
#define btnPin1  D4
#define ledPin1  D2
#define DHTPIN D6
#define DHTTYPE DHT22
//#define TRIGGERPIN D5
//#define ECHOPIN    D6
#define PIN            D7 // GPIO pin
 #define NUMPIXELS      8 // Number of pixels in strip
 Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void checkPhysicalButton();
int ledState = LOW;
int btnState = LOW;
int ledState1 = LOW;
int btnState1 = LOW;
DHT dht(DHTPIN, DHTTYPE);
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  // Request the latest state from the server
  Blynk.syncVirtual(V12);
  Blynk.syncVirtual(V13);
  Blynk.syncVirtual(V20);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V2, ledState);
// When App button is pushed - switch the state
BLYNK_WRITE(V12) {
  ledState = param.asInt();
  digitalWrite(ledPin, ledState);
  Serial.println(!ledState);
BLYNK_WRITE(V13) {
  ledState1 = param.asInt();
  digitalWrite(ledPin1, ledState1);
  Serial.println(!ledState1);
BLYNK_WRITE(V20) // Widget WRITEs to Virtual Pin V10
int R = param[0].asInt();
int G = param[1].asInt();
int B = param[2].asInt();
  Serial.println(R);
  Serial.println(G);
  Serial.println(B);
for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(R,G,B)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
  if (digitalRead(btnPin) == LOW) {
    // btnState is used to avoid sequential toggles
    if (btnState != LOW) {
      // Toggle LED state
      ledState = !ledState;
      // Update Button Widget
      Blynk.virtualWrite(V12, ledState);
    btnState = LOW;
    btnState = HIGH;
  if (digitalRead(btnPin1) == LOW) {
    if (btnState1 != LOW) {
      // Toggle LED state
      ledState1 = !ledState1;
      Blynk.virtualWrite(V13, ledState1);
    btnState1 = LOW;
    btnState1 = HIGH;
void sendSensor(){
  float h = (int)dht.readHumidity();
  float t = (int)dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h) || isnan(t)) {
  Blynk.virtualWrite(V15, h);
  Serial.println(h);
  Blynk.virtualWrite(V16, t);
  Serial.println(t);
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT);
  pinMode(ledPin1, OUTPUT);
  pinMode(btnPin1, INPUT);
 // pinMode(TRIGGERPIN, OUTPUT);
 // pinMode(ECHOPIN, INPUT);
  Blynk.begin(auth, ssid, pass, server,8080);
  dht.begin();
  pixels.begin();
 pixels.show();
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton);
  timer.setInterval(6000L, sendSensor);
#2
Please edit your post to add triple backticks at the beginning and end of your code, so that it displays correctly.
Once you’ve done that we’ll explain why your physical button isn’t working, and what to do to resolve the problem.
Okay, thanks for editing your post.
You’re using Blynk.begin, which is a blocking function. If your device can’t connect to Blynk for whatever reason then the code will never progress beyond that line until a connection to Blynk is established.
The solution is to re-write your code do that it uses Blynk.connect instead. This isn’t a straightforward swap of one command for another, it requires you to set-up the Wi-Fi connection first and use the Blynk.config command to specify the Blynk parameters.
The various firmware connection methods are described here:
If you search the forum for keywords like “Blynk.connect” and “Offline operation” then you’ll find code examples which will give you a good starting point.
#4
Thank you very much for your Information !
