My first project!
Hello everyone,
I bought 2 weeks agos the OSOYOO Yun IoT Smart Home Kit and I still have the same problem whatever I did!
I try to control a LED via Blink with this code :
http://osoyoo.com/2018/02/05/osoyoo-yun-iot-led-blink/
I’ve got this 2 errors :
  1. On blink : “blink not online yet”
  2. On the serial monitor : “Impossible to connect” and “Does the sketch use the bridge?”
Any advices to progress about this problem would be helpfull !
I use 1.8.10 IDE and Yun shield V&.1.6.
Many thanks.
That code is setup for a bridge for some reason. Try the sketch builder at the top of this forum first…
Edit:
Dnt know anything about the board but in the sketch builder you can select Arduino Yun and Yun Bridge for internet connection :man_shrugging:
I tried sketch builder with Arduino Yune, Yun Bridge and for the example Blynk Blynk.
The transfer seems ok : “avrdude done.”
What do I need to do on my smartphone and Blynk to see if it works ?
Thank you
The comments in the shetch builder sketch will tell you what widgets to add to the app and how to configure them.
