My esp8266-01 sends no signal
I have a esp8266 esp-01, connected with arduino uno, and I have a project using blynk to connect 1 channel relay module, the relay is not serial (Digital), but in my blynk application, after I send the command to turn on, the relay does not change, already tried to turn on a led and also did not turn on.
My program:
#include “ESP8266_Lib.h”
#include “BlynkSimpleShieldEsp8266.h”
char auth[] = “-9J25Bv5mWH9JHgPjPye8X29yw8tpRKP”;
// Set password to “” for open networks.
char ssid[] = “fofoof”;
char pass[] = “fogolivre”;
#include “SoftwareSerial.h”
SoftwareSerial EspSerial(9, 8); // RX, TX
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
BLYNK_WRITE(V0){
int pinValue = param.asInt();
//Serial.println(pinValue);
if (pinValue == 1) {
digitalWrite (10,0); // liga o relé 01
digitalWrite(10, 1); // desliga o relé 01
void setup(){
void loop(){
Please edit your post to add triple backticks at the beginning and end of your code so that it displays correctly.
Maybe once you have edited your code we can help… There is some stuff going on that don’t look right…
