My esp32 got disconnected/offline after 5 days
Hii…
I made a small home automation with 5 switch manual control it was working fine but after 4 to 5 days it’s disconnected/offline automatically even my switches was not working totally freeze but after I reset it was working fine has before then again i facing the same issue after 4/5 days please tell me some solutions
Hey there,
you should provide more details like blynk IOT or legacy, hardware type, library version, connection method, etc. Otherwise we can’t help you.
And his code :stuck_out_tongue_winking_eye:
Yes definitely
@Nmk - The issues can vary with different platforms so some check points to look at:
First check that you are using the correct libraries and all hardware has the latest firmware.
  1. If using sample code, it is just that, samples code and not intended to operate forever.
  2. Set basic debug points and use these to check where the issue is raised.
  3. Ensure that your Internet connection is good (Wi-Fi / GSM, etc)
  4. Implement the different Blynk handlers, i.e. "disconnected’ and etc.
  5. Lastly, the more information you provide the easier it is to assist
Im using Blynk IOT and this my code
#define BLYNK_TEMPLATE_ID "TBPL-AKjw-rf"
#define BLYNK_DEVICE_NAME "HOME AUTOMATION"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
//#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
// define the GPIO connected with Relays and switches
#define RelayPin1 15  //D23
#define RelayPin2 2  //D22
#define RelayPin3 4  //D21
#define RelayPin4 22  //D19
#define SwitchPin1 32  //D13
#define SwitchPin2 35  //D12
#define SwitchPin3 34  //D14
#define SwitchPin4 39  //D27
#define VPIN_BUTTON_1    V5
#define VPIN_BUTTON_2    V6
#define VPIN_BUTTON_3    V7
#define VPIN_BUTTON_4    V8
#define VPIN_BUTTON_C    V9
#define VPIN_BUTTON_B    V10
// Relay State
bool toggleState_1 = HIGH; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = HIGH; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = HIGH; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = HIGH; //Define integer to remember the toggle state for relay 4
// Switch State
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
#include "BlynkEdgent.h"
BlynkTimer timer2;
BLYNK_CONNECTED() {
//  // Request the latest state from the server
  Blynk.syncVirtual(VPIN_BUTTON_1);
  Blynk.syncVirtual(VPIN_BUTTON_2);
  Blynk.syncVirtual(VPIN_BUTTON_3);
   Blynk.syncVirtual(VPIN_BUTTON_4);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  if(toggleState_1 == 1){
    digitalWrite(RelayPin1, HIGH);
  else {
    digitalWrite(RelayPin1, LOW);
BLYNK_WRITE(VPIN_BUTTON_2) {
  toggleState_2 = param.asInt();
  if(toggleState_2 == 1){
    digitalWrite(RelayPin2, HIGH);
  else {
    digitalWrite(RelayPin2, LOW);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  if(toggleState_3 == 1){
    digitalWrite(RelayPin3, HIGH);
  else {
    digitalWrite(RelayPin3, LOW);
BLYNK_WRITE(VPIN_BUTTON_4) {
  toggleState_4 = param.asInt();
  if(toggleState_4 == 1){
    digitalWrite(RelayPin4, HIGH);
  else {
    digitalWrite(RelayPin4, LOW);
BLYNK_WRITE(VPIN_BUTTON_C) {
  all_SwitchOff();
BLYNK_WRITE(VPIN_BUTTON_B) {
  all_SwitchON();
void all_SwitchOff(){
  toggleState_1 = 0; digitalWrite(RelayPin1, LOW); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
  toggleState_2 = 0; digitalWrite(RelayPin2, LOW); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
  toggleState_3 = 0; digitalWrite(RelayPin3, LOW); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
  toggleState_4 = 0; digitalWrite(RelayPin4, LOW); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
void all_SwitchON(){
  toggleState_1 = 1; digitalWrite(RelayPin1, HIGH); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
  toggleState_2 = 1; digitalWrite(RelayPin2, HIGH); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
  toggleState_3 = 1; digitalWrite(RelayPin3, HIGH); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
  toggleState_4 = 1; digitalWrite(RelayPin4, HIGH); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  //During Starting all Relays should TURN OFF
  BlynkEdgent.begin();
    BlynkEdgent.run();
    manual_control(); //Manual Switch Control
    timer2.run();
i was using Blynk disconnected and reconnect on legacy but i dont know how to use this on blynk IOT
@Nmk please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
@PeteKnight done
What’s in your manual_control() function?
extern "C" {
  void app_loop();
  void eraseMcuConfig();
  void restartMCU();
#include "Settings.h"
#include <BlynkSimpleEsp32_SSL.h>
#ifndef BLYNK_NEW_LIBRARY
#error "Old version of Blynk library is in use. Please replace it with the new one."
#endif
#if !defined(BLYNK_TEMPLATE_ID) || !defined(BLYNK_DEVICE_NAME)
#error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
#endif
#include "BlynkState.h"
#include "ConfigStore.h"
#include "ResetButton.h"
#include "ConfigMode.h"
#include "Indicator.h"
#include "OTA.h"
void manual_control();
inline
void BlynkState::set(State m) {
  if (state != m && m < MODE_MAX_VALUE) {
    DEBUG_PRINT(String(StateStr[state]) + " => " + StateStr[m]);
    state = m;
    // You can put your state handling here,
    // i.e. implement custom indication
void printDeviceBanner()
  Blynk.printBanner();
  DEBUG_PRINT("--------------------------");
  DEBUG_PRINT(String("Product:  ") + BLYNK_DEVICE_NAME);
  DEBUG_PRINT(String("Hardware: ") + BOARD_HARDWARE_VERSION);
  DEBUG_PRINT(String("Firmware: ") + BLYNK_FIRMWARE_VERSION " (build " __DATE__ " " __TIME__ ")");
  if (configStore.getFlag(CONFIG_FLAG_VALID)) {
    DEBUG_PRINT(String("Token:    ...") + (configStore.cloudToken+28));
  DEBUG_PRINT(String("Device:   ") + BLYNK_INFO_DEVICE + " @ " + ESP.getCpuFreqMHz() + "MHz");
  DEBUG_PRINT(String("MAC:      ") + WiFi.macAddress());
  DEBUG_PRINT(String("Flash:    ") + ESP.getFlashChipSize() / 1024 + "K");
  DEBUG_PRINT(String("ESP sdk:  ") + ESP.getSdkVersion());
  DEBUG_PRINT(String("Chip rev: ") + ESP.getChipRevision());
  DEBUG_PRINT(String("Free mem: ") + ESP.getFreeHeap());
void runBlynkWithChecks() {
  if (BlynkState::get() == MODE_RUNNING) {
    if (!Blynk.connected()) {
      if (WiFi.status() == WL_CONNECTED) {
        BlynkState::set(MODE_CONNECTING_CLOUD);
        BlynkState::set(MODE_CONNECTING_NET);
class Edgent {
public:
  void begin()
    indicator_init();
    button_init();
    config_init();
    WiFi.persistent(false);
    WiFi.enableSTA(true);   // Needed to get MAC
    printDeviceBanner();
    } else if (config_load_blnkopt()) {
      DEBUG_PRINT("Firmware is preprovisioned");
      BlynkState::set(MODE_WAIT_CONFIG);
  void run() {
    app_loop();
    switch (BlynkState::get()) {
    case MODE_WAIT_CONFIG:
    case MODE_CONFIGURING:       enterConfigMode();    break;
    case MODE_CONNECTING_NET:    enterConnectNet();    break;
    case MODE_CONNECTING_CLOUD:  enterConnectCloud();  break;
    case MODE_RUNNING:           runBlynkWithChecks(); break;
    case MODE_OTA_UPGRADE:       enterOTA();           break;
    case MODE_SWITCH_TO_STA:     enterSwitchToSTA();   break;
    case MODE_RESET_CONFIG:      enterResetConfig();   break;
    default:                     enterError();         break;
Edgent BlynkEdgent;
BlynkTimer timer3;
void app_loop() {
    timer3.run();
    manual_control();
  if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
    Blynk.virtualWrite(VPIN_BUTTON_1, HIGH);
    SwitchState_1 = HIGH;
    Serial.println("Switch-1 on");
  if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
    Blynk.virtualWrite(VPIN_BUTTON_1, LOW);
    toggleState_1 = LOW;
    SwitchState_1 = 0;
    Serial.println("Switch-1 off");
  if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
    Blynk.virtualWrite(VPIN_BUTTON_2, HIGH);
    SwitchState_2 = HIGH;
    Serial.println("Switch-2 on");
  if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
    Blynk.virtualWrite(VPIN_BUTTON_2, LOW);
    toggleState_2 = LOW;
    Serial.println("Switch-2 off");
  if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
    Blynk.virtualWrite(VPIN_BUTTON_3, HIGH);
    SwitchState_3 = HIGH;
    Serial.println("Switch-3 on");
  if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
    Blynk.virtualWrite(VPIN_BUTTON_3, LOW);
    toggleState_3 = LOW;
    Serial.println("Switch-3 off");
  if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
    Blynk.virtualWrite(VPIN_BUTTON_4, HIGH);
    SwitchState_4 = HIGH;
    Serial.println("Switch-4 on");
  if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
    Blynk.virtualWrite(VPIN_BUTTON_4, LOW);
    toggleState_4 = LOW;
    Serial.println("Switch-4 off");
You should read this…
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
