My device is yet show offline
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  =>          USB HOWTO: http://tiny.cc/BlynkUSB
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - Arduino Uno board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
#define BLYNK_PRINT SwSerial
char auth[] = "8272b13b2cbf4d66a8f0145cbe0d76ea";
  SwSerial.begin(9600);
  Blynk.begin(Serial, auth);
  // to avoid delay() function!
i chose proper port but sill show offline
Welcome,
You didn’t mention the exact hardware and connection method you are using… but it looks like it is an Arduino with USB.
http://help.blynk.cc/how-to-connect-different-hardware-with-blynk/arduino/usb-serial
Read the documents in the Help Center for more information on how to setup your sketches for best Blynk usage. How to connect different hardware as well as timers instead of delay() and timed functions instead of dumping everything into the void loop()
Also check out the Sketch Builder for more sketch examples.
https://examples.blynk.cc/?board=Arduino%20Uno&shield=Arduino%20WiFi%20Shield&example=GettingStarted%2FBlynkBlink
