My device is offline - blynk can't find the device
boolean debug = true; // Change to false for no debug (serial off)
#define INT_PIN 13 // Interrupt pin number
#define BLYNK_PRINT Serial // Uncomment this for first run or debugging.
#include <ESP8266WiFi.h> // Library for ESP8266 WiFi functionality. Needs to be included if we want to connect to WiFi.
#include <BlynkSimpleEsp8266.h> // Blynk library. Needs to be included so we can send data to Blynk.
#include <SPI.h> // SPI library
#include <SD.h> // SD card library
#include “Wire.h” // I2C library
#include <MAX17043.h> // MAX17043 library
// System variables
unsigned int i = 0; // frequency conter
float flow = 0; // flow in l/min
float a_flow = 0; // average flow in l/min
float t_water = 0; // total amount of water
float voltage = 0; // battery voltage
float charge = 0; // battery charge
const int Ts = 2; // Sampling rate
unsigned int c = 0; // cycle counter
// Functions
void getFlow();
void logFlow();
void logFlowBlynk();
void checkBattery();
// ISR, Interrupt routine
void counter(){
i++;
// Blynk tokken
// You should get your Auth Token in the Blynk App.
char auth[] = “”;
// Set password to “” for open networks.
char ssid[] = “”;
char pass[] = “ma0506385325”;
MAX17043 batteryMonitor;
// Initialize digital pin 2 as an output.
pinMode(2, OUTPUT); // Blue LED
pinMode(INT_PIN, INPUT); // Interrupt pin
if(debug){
// I2C for Fuel gauge
Wire.begin(4,5); // Start I2C interface on Arduino pins 4 (SDA) and 5 (SCL)
batteryMonitor.reset();
batteryMonitor.quickStart();
// SD card
if (!SD.begin(15)){
Serial.println(“Card failed, or not present”);
// don’t do anything more:
return;
Serial.println(“Card detected”);
// Blynk setup
//wifi_set_sleep_type(MODEM_SLEEP_T);
void loop(){
getFlow();
logFlow();
if(c==26){
// Update server
checkBattery();
logFlowBlynk();
c=0;
// Total amount of water correction
t_water = t_water + (flow/60)Ts3;
delay(50);
}else{
c++;
delay(950);
in the monitor it connects to blynk but in the app its offline
void getFlow(){
i=0; // reset counter to zero
// Start interrupts on INT_PIN
attachInterrupt(digitalPinToInterrupt(INT_PIN), counter, RISING);
delay(1000); // count pulses in one seconds; i = frequency
detachInterrupt(digitalPinToInterrupt(INT_PIN));
flow = i / 7.5; // according to manufacturer this is how flow is calculated from frequency
t_water = t_water + (flow/60)*Ts;
a_flow = ( a_flow/2 ) + ((flow/60)/2 );
if(debug){
Serial.print(“Frequency: “);
Serial.print(i);
Serial.println(” Hz”);
Serial.print(“Flow: “);
Serial.print(flow);
Serial.println(” l/min”);
Serial.print(“Average flow: “);
Serial.print(a_flow);
Serial.print(“Total amount of water: “);
Serial.print(t_water);
Serial.println(” l”);
void logFlow(){
// Prep data
String dataString = String(flow) + “,” + String(a_flow) + “,” + String(t_water);
// Open file
File dataFile = SD.open(“datalog.txt”, FILE_WRITE);
// If the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
// Close file
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn’t open, pop up an error:
else {
Serial.println(“error opening datalog.txt”);
void logFlowBlynk(){
// Send data
Blynk.virtualWrite(V0, a_flow); // Writing Average flow to Virtual pin V0.
Blynk.virtualWrite(V1, t_water); // Writing Total amound of water to Virtual pin V1.
Blynk.virtualWrite(V2, voltage); // Writing battery voltage level to Virtual pin V2.
Blynk.virtualWrite(V3, charge); // Writing battery charge status to Virtual pin V3.
// Send email alarm on battery voltage
if(voltage < 3.2){ // If voltage is below 3.2V, send alarm.
Blynk.email("my_email@example.com", “Battery low”, “Hey. Flow meter here. Please charge me!”);
Serial.println(“Update complete”);
void checkBattery(){
// Check battery charge status
voltage = batteryMonitor.getVCell();
Serial.print(“Voltage:\t\t”);
Serial.print(voltage, 4);
Serial.println(“V”);
// Check battery voltage
charge = batteryMonitor.getSoC();
Serial.print(“State of charge:\t”);
Serial.print(charge);
Serial.println("%");
Hello. Please use code formatting. Also what does mean “Blynk can’t find the device”?
it the app when you press the play butten the app writers that the device offline
Please start with http://docs.blynk.cc/#troubleshooting in that case.
@Ariel_Altura you need to Blynkify your sketch now that you have moved from Arduino processing to iOT control.
Briefly this means you must use SimpleTimer (one of the 6 libraries you manually installed) , no delays and 2 lines of code in loop().
More detail at http://community.blynk.cc/t/10000
