My code is not able to compile and is showing error with the blynk library
Hi i am using raspberry pi for my project and i require to control the humidity and temperature via cloud i used Blynk for that… but the compiler is showing error in the BlynkLib it ran well for the first time but now it shows this error
___  __          __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ for Python v1.0.0 (linux)
Connecting to blynk.cloud:443…
Traceback (most recent call last):
File “/home/hydro/blynk-library-python/aum.py”, line 15, in
blynk = BlynkLib.Blynk(BLYNK_AUTH_TOKEN)
File “/home/hydro/blynk-library-python/BlynkLib.py”, line 214, in init
BlynkProtocol.init(self, auth, **kwargs)
File “/home/hydro/blynk-library-python/BlynkLib.py”, line 81, in init
self.connect()
File “/home/hydro/blynk-library-python/BlynkLib.py”, line 226, in connect
s.connect(socket.getaddrinfo(self.server, self.port)[0][-1])
TypeError: AF_INET address must be a pair (host, port)
SS
my code is as follows
• Hardware model + communication type.: Raspberry pi 3 model b. 1 wire protocol
• Smartphone OS (iOS or Android) + version : using raspberry pi os 32 bit
• Blynk server
• Blynk Library version 1.0.0
import BlynkLib
import RPi.GPIO as GPIO
from BlynkTimer import BlynkTimer
import Adafruit_DHT
import time
DHT_SENSOR = Adafruit_DHT.DHT11
DHT_PIN = 4
BLYNK_AUTH_TOKEN = 'jsfpl_ACPJIVDdkFJ9THE5PkCVvYR8FS'
# Initialize Blynk
# Create BlynkTimer Instance
timer = BlynkTimer()
# function to sync the data from virtual pins
@blynk.on("connected")
def blynk_connected():
    print("Hi, You have Connected to New Blynk2.0")
    print(".......................................................")
    print("................... By SME Dehradun ...................")
    time.sleep(2);
# Functon for collect data from sensor & send it to Server
def myData():
    humidity, temperature = Adafruit_DHT.read(DHT_SENSOR, DHT_PIN)
    if humidity is not None and temperature is not None:
        print("Temp={0:0.1f}C Humidity={1:0.1f}%".format(temperature, humidity))
    else:
        print("Sensor failure. Check wiring.");
    blynk.virtual_write(0, humidity,)
    blynk.virtual_write(1, temperature)
    print("Values sent to New Blynk Server!")
timer.set_interval(2, myData)
while True:
    blynk.run()
    timer.run()
kindly help me
