I was using a massive 84x48 pixel display… so yours will be a tight squeeze, but workable ![]()
I think if you comment out or remove these lines, then everything will work “normal” with a larger display.
Thanks. Not sure when, but certainly will comment here my results.
I am too lazy to make a proper YouTube video
… but here is a GIF of my current alliteration… I realise now that you can’t really see the data scrolling by in the top half of the LCD…
I merged in my above redirection code and a Virtual LED matrix code (not showing, but running in another tab) and now also containing random servo moves and CPU temp checks - Basically a programming test bench for my ESP32.
The top half of the screen is a scrolling account of any Blynk prints, logs & errors, plus any timer based “serial” prints I make, actually myConsole.println(), such as RSSI and time/date stamps.
While the bottom half is a direct screen print of real-time data like Servo position and CPU temp.
One benefit I have already noticed is that occasionally my ESP seemed to loose Blynk connection… but even while originally using Blynk.begin() and without any coded checks or Blynk.run() bypasses, somehow keep on running everything else in the code?? maybe an automatic dual core ESP32 thing??
Anyhow… so I never really knew it was disconnected until I checked the App. But now I can see the "connecting to… " message in the screen
I have since added in Blynk.config() and re-connection routines
Well, I am not sure where my fascination with displays and LEDs comes from… probably the whole visual understanding thing… but I can’t leave this one alone
So I finally managed to get my little SSD1331, a 96x64 Full Colour OLED display (that I had previously wired as a Wemos shield) and added in this Blynk print redirection… so far so good.
The best library I found for this OLED for speed is an older one. https://github.com/sumotoy/SSD_13XX But very fast and relatively easy to program for… just lousy / non-existent directions for all the commands… have to spend lots of time dissecting and testing from the library files.
It allows simpler Blynk Print setup and word wrapping… which makes it much nicer to just dump test to
It even has a small collection of external fonts. Unfortunately, the font that looks the best for the Blynk Logo (Terminal_9) is a bit too big… so only half a logo for me
But the display (or libraries) built-in font is fairly OK, and shows more text.
And a sketch for the ESP8266 and the ssd1331 OLED
//#define BLYNK_DEBUG
#define BLYNK_NO_BUILTIN // Disable Blynk's built-in analog & digital pin operations
#include <SSD_13XX.h>
#include "_fonts/Terminal_9.c"
#define __CS_TFT 16 // pin D0
#define __DC_TFT 15 // pin D8
SSD_13XX tft = SSD_13XX(__CS_TFT, __DC_TFT);
class CustomConsole
: public Print // This automatically adds functions like .println()
public:
CustomConsole() {}
virtual size_t write(uint8_t ch) { // Grabs character from print
tft.setTextWrap(false); // Enable/disable word wrapping
tft.setFontInterline(1); // Add single pixel in-between lines
tft.print(char(ch)); // print character to OLED
Serial.print(char(ch)); // Repeat all character output to Serial monitor
if (ch == '\n') { // End of line check
line ++;
if (line >= 7 ) { // Last line on screen check
line = 0; // Reset line counter
if (firstScreen == 0) {
firstScreen = 1;
delay(5000); // One-time delay to view Logo :)
delay(500); // Small delay to allow viewing of last line befor screen clear
tft.clearScreen();
} // End screen wrap
} // End line count
return 1; // Processed 1 character
} // End character print
private:
int line = 0;
int firstScreen = 0;
CustomConsole myConsole;
#define BLYNK_PRINT myConsole
char auth[] = "xxxxxxxxxx"; // Local Server
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char server[] = "xxx.xxx.xxx.xxx";
int port = 8080;
tft.begin();
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
// Timed Lambda Function - UpTime counter
timer.setInterval(1000L, []() { // Run every second
Blynk.virtualWrite(V0, millis() / 1000); // Display the UpTime in Minutes to App
myConsole.println(millis() / 1000); // Display the UpTime in Minutes to OLED and Serial
}); // END Timer Function
And my latest addition to this Blynk Serial Display phase I am on…
The TTG ESP32 with OLED & 18650
Tiny screen, but good resolution (128x64)… hard to focus up close
#define BLYNK_MAX_READBYTES 1024
#define BLYNK_MSG_LIMIT 0
#define BLYNK_HEARTBEAT 60
#include <U8g2lib.h> // For OLED
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0,/* reset=*/ U8X8_PIN_NONE,/* clock=*/ 4, /* data=*/ 5); // The all important setup for the TTGO's build in OLED
// Define a custom console for OLED debug output
class CustomConsole
public:
CustomConsole() {}
u8g2.print(char(ch)); // Add character to OLED buffer
u8g2.sendBuffer(); // Dump buffer to OLED
line += height; // Increment next line down
if (line >= 72) {
line = height; // Reset line counter
u8g2.setCursor(0, line); // Set curser to next line down
private:
// define variables used in myConsole
int line = 8; // line counter
int height = 8; // Line pixel height
// initiate myConsole
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <ESPmDNS.h> // For OTA
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
#include <TimeLib.h>
#include <WidgetRTC.h>
char server[] = "10.10.3.13";
int port = 8080;
char currentTime[9];
char currentDate[11];
WidgetRTC rtc;
pinMode(16, OUTPUT);
u8g2.setFont(u8g2_font_micro_mr); // choose a suitable font for Logo
u8g2.begin();
timer.setInterval(1010L, TimeDatecheck);
timer.setInterval(2030L, RSSIcheck);
timer.setInterval(3045L, FlashLED);
Blynk.connect();
ArduinoOTA.setHostname("TTGO - OLED & 18650"); // For OTA
ArduinoOTA.begin(); // For OTA
BLYNK_CONNECTED() {
rtc.begin();
setSyncInterval(360); // Time Sync
ArduinoOTA.handle(); // For OTA
void TimeDatecheck() {
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
sprintf(currentDate, "%02d/%02d/%04d", month(), day(), year());
myConsole.print(currentTime);
myConsole.print(" ");
myConsole.print(currentDate);
myConsole.println(" ");
void RSSIcheck() {
Blynk.virtualWrite(V67, WiFi.RSSI()); // RSSI
//myConsole.print("Board #1 - RSSI ");
myConsole.print("Board #2 - RSSI ");
myConsole.print(WiFi.RSSI());
void FlashLED() {
digitalWrite(16, LOW); // Turn ON
delay(100);
digitalWrite(16, HIGH); // Turn OFF
@Gunner can you please provide the full pin details for the OLED you are using. I have 4 or 5 OLED’s that I haven’t used for a year or more. Some have 4 pins but with pins switched around between different models and some have 7 like yours. Might be my lack of soldering skills that’s a problem but I couldn’t get any of them to work. They were working when I last used them but I might have destroyed one of them.
In the old days you had to tweak the libraries to your particular OLED but it looks like most of that is now done in the sketch.
see also:
Some of these similar looking OLEDS apparently can be set for SPI or i2c via soldered jumpers. Or at least the address used for i2c can be assigned in some.
But despite the extra SCL SDA pins, the color SSD1331 I have appears to be only a 4 pin SPI (VCC, GND, DC, CS - RST seems optional depending on the library) I successfully used these pins with my Wemos with that referenced library…
So VCC, GND, D0 and D8?
For VCC are you using 3.3V or 5V?
I have a feeling none of mine are color OLED’s.
I used 5v
Here is a snippet from another random example I used with the adafruit library… It wanted all the pins for Option 1, but I used the Option 2 Hardware SPI mode D0 and D8
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1331.h>
// You can use any (4 or) 5 pins - Wemos D1 Mini used here
#define sclk D5 //--- connect this to the display module SCL pin (Serial Clock)
#define mosi D7 //--- connect this to the display module SDA pin (Serial Data)
#define rst D6 //--- connect this to the display module RES pin (Reset)
#define dc D8 //--- connect this to the display module DC pin (Data or Command)
#define cs D0 //--- connect this to the display module CS pin (Chip Select)
// Option 1: use any pins but a little slower
// Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, rst);
OK I managed to get one of my 4 pin OLED’s working. 3,3V, GND, GPIO 5 SCL (WeMos D1) and GPIO 4 SDA (WeMos D2). This Adafruit sketch displays falling snowflakes on the screen.
SSD1306.ino
This is an example for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
This example is for a 128x32 pixel display using I2C to communicate
3 pins are required to interface (two I2C and one reset).
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source
hardware by purchasing products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries,
with contributions from the open source community.
BSD license, check license.txt for more information
All text above, and the splash screen below must be
included in any redistribution.
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET LED_BUILTIN //4 -1 // 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
static const unsigned char PROGMEM logo_bmp[] =
{ B00000000, B11000000,
B00000001, B11000000,
B00000011, B11100000,
B11110011, B11100000,
B11111110, B11111000,
B01111110, B11111111,
B00110011, B10011111,
B00011111, B11111100,
B00001101, B01110000,
B00011011, B10100000,
B00111111, B11100000,
B00111111, B11110000,
B01111100, B11110000,
B01110000, B01110000,
B00000000, B00110000 };
Serial.println(F("SSD1306 test"));
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
Serial.println(F("OK"));
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
// Draw a single pixel in white
display.drawPixel(10, 10, WHITE);
// Show the display buffer on the screen. You MUST call display() after
// drawing commands to make them visible on screen!
display.display();
delay(2000);
// display.display() is NOT necessary after every single drawing command,
// unless that's what you want...rather, you can batch up a bunch of
// drawing operations and then update the screen all at once by calling
// display.display(). These examples demonstrate both approaches...
testdrawline(); // Draw many lines
testdrawrect(); // Draw rectangles (outlines)
testfillrect(); // Draw rectangles (filled)
testdrawcircle(); // Draw circles (outlines)
testfillcircle(); // Draw circles (filled)
testdrawroundrect(); // Draw rounded rectangles (outlines)
testfillroundrect(); // Draw rounded rectangles (filled)
testdrawtriangle(); // Draw triangles (outlines)
testfilltriangle(); // Draw triangles (filled)
testdrawchar(); // Draw characters of the default font
testdrawstyles(); // Draw 'stylized' characters
testscrolltext(); // Draw scrolling text
testdrawbitmap(); // Draw a small bitmap image
// Invert and restore display, pausing in-between
display.invertDisplay(true);
display.invertDisplay(false);
testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
void testdrawline() {
int16_t i;
display.clearDisplay(); // Clear display buffer
for(i=0; i<display.width(); i+=4) {
display.drawLine(0, 0, i, display.height()-1, WHITE);
display.display(); // Update screen with each newly-drawn line
delay(1);
for(i=0; i<display.height(); i+=4) {
display.drawLine(0, 0, display.width()-1, i, WHITE);
display.display();
delay(1);
delay(250);
display.drawLine(0, display.height()-1, i, 0, WHITE);
display.display();
delay(1);
for(i=display.height()-1; i>=0; i-=4) {
display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
display.display();
delay(1);
delay(250);
for(i=display.width()-1; i>=0; i-=4) {
display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
display.display();
delay(1);
display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
display.display();
delay(1);
delay(250);
display.drawLine(display.width()-1, 0, 0, i, WHITE);
display.display();
delay(1);
display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
display.display();
delay(1);
void testdrawrect(void) {
for(int16_t i=0; i<display.height()/2; i+=2) {
display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
display.display(); // Update screen with each newly-drawn rectangle
delay(1);
delay(2000);
void testfillrect(void) {
for(int16_t i=0; i<display.height()/2; i+=3) {
// The INVERSE color is used so rectangles alternate white/black
display.fillRect(i, i, display.width()-i*2, display.height()-i*2, INVERSE);
delay(1);
delay(2000);
void testdrawcircle(void) {
for(int16_t i=0; i<max(display.width(),display.height())/2; i+=2) {
display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
display.display();
delay(1);
delay(2000);
void testfillcircle(void) {
for(int16_t i=max(display.width(),display.height())/2; i>0; i-=3) {
// The INVERSE color is used so circles alternate white/black
display.fillCircle(display.width() / 2, display.height() / 2, i, INVERSE);
display.display(); // Update screen with each newly-drawn circle
delay(1);
delay(2000);
void testdrawroundrect(void) {
for(int16_t i=0; i<display.height()/2-2; i+=2) {
display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i,
display.height()/4, WHITE);
display.display();
delay(1);
delay(2000);
void testfillroundrect(void) {
// The INVERSE color is used so round-rects alternate white/black
display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i,
display.height()/4, INVERSE);
display.display();
delay(1);
delay(2000);
void testdrawtriangle(void) {
for(int16_t i=0; i<max(display.width(),display.height())/2; i+=5) {
display.drawTriangle(
display.width()/2 , display.height()/2-i,
display.width()/2-i, display.height()/2+i,
display.width()/2+i, display.height()/2+i, WHITE);
display.display();
delay(1);
delay(2000);
void testfilltriangle(void) {
for(int16_t i=max(display.width(),display.height())/2; i>0; i-=5) {
// The INVERSE color is used so triangles alternate white/black
display.fillTriangle(
display.width()/2+i, display.height()/2+i, INVERSE);
display.display();
delay(1);
delay(2000);
void testdrawchar(void) {
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(WHITE); // Draw white text
display.setCursor(0, 0); // Start at top-left corner
display.cp437(true); // Use full 256 char 'Code Page 437' font
// Not all the characters will fit on the display. This is normal.
// Library will draw what it can and the rest will be clipped.
for(int16_t i=0; i<256; i++) {
if(i == '\n') display.write(' ');
else display.write(i);
display.display();
delay(2000);
void testdrawstyles(void) {
display.setCursor(0,0); // Start at top-left corner
display.println(F("Hello, world!"));
display.setTextColor(BLACK, WHITE); // Draw 'inverse' text
display.println(3.141592);
display.setTextSize(2); // Draw 2X-scale text
display.print(F("0x")); display.println(0xDEADBEEF, HEX);
display.display();
delay(2000);
void testscrolltext(void) {
display.setCursor(10, 0);
display.println(F("scroll"));
display.display(); // Show initial text
delay(100);
// Scroll in various directions, pausing in-between:
display.startscrollright(0x00, 0x0F);
delay(2000);
display.stopscroll();
display.startscrollleft(0x00, 0x0F);
delay(2000);
display.startscrolldiagright(0x00, 0x07);
delay(2000);
display.startscrolldiagleft(0x00, 0x07);
delay(2000);
void testdrawbitmap(void) {
display.drawBitmap(
(display.width() - LOGO_WIDTH ) / 2,
(display.height() - LOGO_HEIGHT) / 2,
logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
display.display();
#define XPOS 0 // Indexes into the 'icons' array in function below
#define YPOS 1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
int8_t f, icons[NUMFLAKES][3];
// Initialize 'snowflake' positions
for(f=0; f< NUMFLAKES; f++) {
icons[f][XPOS] = random(1 - LOGO_WIDTH, display.width());
icons[f][YPOS] = -LOGO_HEIGHT;
icons[f][DELTAY] = random(1, 6);
Serial.print(F("x: "));
Serial.print(icons[f][XPOS], DEC);
Serial.print(F(" y: "));
Serial.print(icons[f][YPOS], DEC);
Serial.print(F(" dy: "));
Serial.println(icons[f][DELTAY], DEC);
for(;;) { // Loop forever...
display.clearDisplay(); // Clear the display buffer
// Draw each snowflake:
display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, WHITE);
display.display(); // Show the display buffer on the screen
delay(200); // Pause for 1/10 second
// Then update coordinates of each flake...
icons[f][YPOS] += icons[f][DELTAY];
// If snowflake is off the bottom of the screen...
if (icons[f][YPOS] >= display.height()) {
// Reinitialize to a random position, just off the top
That’ll be your 7 day weather forecast then! ![]()
Up in the Troodos mountains, perhaps.
Yes it turns out that the 2 OLED’s I have with 7 pins can be configured differently if I get out the iron, which I’m reluctant to do. There is a default setting that should work but I haven’t got them running yet.
Of the 3 OLED’s I have with 4 pins one appears to be dead. One displays white text and the resolution is very poor. I have to set a fontsize of 2 for it to be clear enough to read but then it is too big to get very much text on the display.
The third one is quite nice and displays blue text with fontsize 1 being crystal clear if you have 20:20 vision, which I don’t.
I tweaked your code to display a line of text at a time rather than a single character. With the single character format it was like watching an IBM terminal from the 1970’s
Also after displaying the Blynk logo I enable text wrapping to the display.
I have two versions of your code:
First version
Allows BLYNK_DEBUG to be sent to the OLED and has a separate class for CustomTerminal. As Terminal only works once the connection has been made you don’t get to see the logo in the Terminal so I have:
BLYNK_CONNECTED()
myTerminal.println(F("Connected to Blynk"));
myTerminal.print(F("Local IP: "));
myTerminal.println(WiFi.localIP());
Second version
Just one print class to send text to Serial Monitor or Terminal, without an OLED. Useful when your project doesn’t have access to a Serial Monitor. By using myConsole.println() you don’t have to edit a long sketch which might be littered with Serial.println() and Blynk.virtualWrite(Vx, “text to terminal”) commands.
SM2Terminal.ino Send Serial Monitor data to Blynk Terminal
Terminal widget on V0
#define serialavailable // comment out when Serial Monitor is not available
class CustomConsole
: public Print
public:
CustomConsole() {}
virtual size_t write(uint8_t ch) // Grabs character from print
fulltext = fulltext + String(char(ch));
if (ch == '\n') // print a line at a time rather than a character at a time
Blynk.virtualWrite(V0, fulltext);
#ifdef serialavailable
Serial.print(fulltext);
#endif
fulltext = "";
return 1; // Sent a line of text to Serial Monitor and Terminal
private:
String fulltext = "";
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
char serv[] = "blynk-cloud.com";
BLYNK_CONNECTED()
myConsole.println(F("Connected to Blynk"));
myConsole.print(F("Local IP: "));
myConsole.println(WiFi.localIP());
void myTimerEvent()
myConsole.println("Uptime: " + String(millis() / 1000));
Serial.begin(74880); // ESP8266 native baud rate
#endif
Blynk.begin(auth, ssid, pass, serv);
OK, this time I am using a bit larger screen then the past ones
like a 20" VGA monitor that is
( UXGA actually)
I spent way more hours then I think I really had in me, today… but I used Bitlune’s wonderfull ESP32 VGA library (in beta)…
And wired up a ESP32 Dev board. I an just using the simple method right now, I will build up the resistor ladder later for higher resolution and color depth.
And sent the display to my workstations secondary monitor’s VGA input.
It is NOT really working properly… as all those numbers at the top are actually the ASCII decimal numbers being printed literally instead of the wanted characters… The characters only show up instead of a uptime counter due to some bug in the library that seems to be flushing a buffer?? If I had let the timer keep going it would repeat the logo minus a top leftmost character each time… and so on until it is just showing gibberish.
And this is mimicked on the Serial monitor. Hard to see, but it is on the right hand monitor and looks like this…
But, hey… I got to display the Blynk logo on VGA and sometimes that is all that is needed to amuse me
#include <ESP32Lib.h>
#include <Ressources/Font6x8.h>
VGA3Bit vga;
class CustomConsole
public:
CustomConsole() {}
vga.print(char(ch)); // Should print a character to VGA, but just shows the decimal value of it
private:
#define BLYNK_PRINT myConsole // Unfortunatly simply using '#define BLYNK_PRINT vga' didn't work at all
//#define BLYNK_DEBUG // Optional, this enables more detailed prints
#include <WiFi.h>
// VGA pin configuration
const int redPin = 14;
const int greenPin = 19;
const int bluePin = 27;
const int hsyncPin = 0;
const int vsyncPin = 5;
char server[] = "xxx.xxx.xxx.xxx"; // IP for your Local Server
int port = 8080;
Serial.begin(74880); // BLYNK_PRINT data
//initializing vga at the specified pins
vga.init(vga.MODE320x240, redPin, greenPin, bluePin, hsyncPin, vsyncPin);
//selecting the font
vga.setFont(Font6x8);
//clearing with Green background
//vga.clear(vga.RGB(0x009900)); // BBGGRR
//black text color no background color
//vga.setTextColor(vga.RGB(1));
int uptime = millis() / 1000;
Blynk.virtualWrite(V1, uptime); // Display the UpTime in Seconds
Serial.print(uptime + ", ");
vga.print(uptime + ", "); // This adding of the comma seems to cause some buffer issue that while actually displaying the proper characters since boot... never properly displays the uptime for a while.
Blynk.connect();
Serial.println("Hello World");
vga.println("Hello World");
OK, I think I have it beat… using a refreshing character array of a whopping 2 bytes (if I am using the terminology correct). It will display any and all Blynk log, DEBUG and vga.println() commands as needed.
Now we can have a totally independent ESP32/ Blynk setup complete with diagnostics/screen display.
Although it might help to have a much smaller VGA capable display if you wish to make it portableish
VGA3Bit vga;
char text[2] = {};
int i = 0;
class CustomConsole
: public Print { // This automatically adds functions like .println()
public:
CustomConsole() {}
text[i] += char(ch);
i++;
if (i == 2) {
vga.print(text);
for (int j = 0; j < i; j++) {
text[j] = '\0';
i = 0;
private:
#include <WiFi.h>
//pin configuration
int RPM;
int maxRPM;
int port = 8080;
Serial.begin(115200); // BLYNK_PRINT data
//clearing with coloured background
vga.clear(vga.RGB(0xff0000)); // BBGGRR
timer.setInterval(60000L, []() { // Run every second
int uptime = millis() / 60000;
Serial.print("Up for: ");
Serial.print(uptime);
Serial.println(" Minutes");
vga.print("Up for: ");
vga.print(uptime);
vga.println(" Minutes");
Blynk.connect();
Serial.println("Hello World!!\n");
vga.println("Hello World!!\n");
@Gunner, see where bitluni saw your post?
Its briefly on the screen at about 10 seconds in or so. Pretty cool!
