I am having the most horrible time today for some reason and cannot seem to figure this out. I’m at the point I would be willing to pay for assistance. PLEASE HELP!!
For some reason there with three timers can’t seem to figure out how the heck to get them all to work at “once”. It seems as though when two of them are in the same time range then they all lock up and don’t do anything. I’ve tried varying the timer interval and also the duration of the timer by a couple seconds, when they should be the same, however it never fails they always lock up when two-three of the sliders have a similar timer set.
Your help is appreciated.
#define PIN 14
#define PIN 12
#define PIN 13
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int finishedCycle = 1;
int relayPin = 14; // adjust accordingly
int piezoPin1 = 14;
int piezoPin2 = 12;
int piezoPin3 = 13;
int timerNo1; // ID of timer to start stop
int timerNo2; // ID of timer to start stop
int timerNo3; // ID of timer to start stop
int timerNo4; // ID of timer to start stop
int timerNo5; // ID of timer to start stop
int timerNo6;
int timerNo7;
int timerNo8;
int timerNo9;
int timerNo10;
int timerNo11;
int timerNo12;
int timerNo13;
int timerNo14;
int timerNo15;
int onState = 0; // 1 is On 0 is Off
int onTime1 = 20; // seconds
//9seconds
int offTime1 = 20; // seconds
//22 seconds
int onTime2 = 15;
//12.5
int offTime2 = 15;
//3
int onTime3 = 10;
//2,5
int offTime3 = 10;
int onTime4 = 5;
int offTime4 = 5;
int onTime5 = 1;
int offTime5 = 1;
int onTime5two = 1;
int offTime5two = 1;
int onTime5three = 1;
int offTime5three = 1;
int timerID = 1;
int peizoOn1;
int piezoOn2;
int piezpoOn3;
boolean isOn = false; // toggle flag for relay
/*BLYNK_WRITE(V19) //Refresh finishedCycle from server
finishedCycle = param.asInt();
//first slider test!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BLYNK_WRITE(V6)
finishedCycle = 0; // Sets cycle as begun
Blynk.virtualWrite(V19, finishedCycle); //write value to server
onState = param.asInt();
if (onState == 1)
timer.disable(timerNo1); // Turn off
timer.disable(timerNo2); // Turn off
timer.disable(timerNo3); // Turn off
timer.disable(timerNo4); // Turn off
timer.disable(timerNo5); // Turn off
onOffToggler1(); // Turn on
else if (onState == 2)
onOffToggler2(); // Turn on
else if (onState == 3)
onOffToggler3(); // Turn on
else if (onState == 4)
onOffToggler4(); // Turn on
else if (onState == 5)
onOffToggler5(); // Turn on
digitalWrite(piezoPin1, LOW);
// Set button to switch mode
// MCU operations
void onOffToggler1()
timer.deleteTimer(timerNo1);
if (!isOn)
// finishedCycle++; // Sets cycle as begun
// Blynk.virtualWrite(V19, finishedCycle); //write value to server
digitalWrite(piezoPin1, HIGH);
timerNo1 = timer.setInterval(onTime1 * 1000L, onOffToggler1);
isOn = true;
// finishedCycle = 0; // Sets cycle as begun
timerNo1 = timer.setInterval(offTime1 * 1000L, onOffToggler1);
isOn = false;
void onOffToggler2()
timer.deleteTimer(timerNo2);
if (!isOn)
timerNo2 = timer.setInterval(onTime2 * 1000L, onOffToggler2);
isOn = true;
timerNo2 = timer.setInterval(offTime2 * 1000L, onOffToggler2);
isOn = false;
void onOffToggler3()
timer.deleteTimer(timerNo3);
if (!isOn)
timerNo3 = timer.setInterval(onTime3 * 1000L, onOffToggler3);
isOn = true;
timerNo3 = timer.setInterval(offTime3 * 1000L, onOffToggler3);
isOn = false;
void onOffToggler4()
timer.deleteTimer(timerNo4);
if (!isOn)
timerNo4 = timer.setInterval(onTime4 * 1000L, onOffToggler4);
isOn = true;
timerNo4 = timer.setInterval(offTime4 * 1000L, onOffToggler4);
isOn = false;
void onOffToggler5()
timer.deleteTimer(timerNo5);
if (!isOn)
timerNo5 = timer.setInterval(onTime5 * 1000L, onOffToggler5);
isOn = true;
timerNo5 = timer.setInterval(offTime5 * 1000L, onOffToggler5);
isOn = false;
BLYNK_WRITE(V10)
Blynk.virtualWrite(V20, finishedCycle); //write value to server
if (onState == 1)
timer.disable(timerNo6); // Turn off
timer.disable(timerNo7); // Turn off
timer.disable(timerNo8); // Turn off
timer.disable(timerNo9); // Turn off
timer.disable(timerNo10); // Turn off
onOffToggler6(); // Turn on
onOffToggler7(); // Turn on
onOffToggler8(); // Turn on
onOffToggler9(); // Turn on
onOffToggler10(); // Turn on
digitalWrite(piezoPin3, LOW);
// MCU operations
void onOffToggler6()
timer.deleteTimer(timerNo6);
if (!isOn)
// Blynk.virtualWrite(V20, finishedCycle); //write value to server
digitalWrite(piezoPin3, HIGH);
timerNo6 = timer.setInterval(onTime1 * 1000L, onOffToggler6);
isOn = true;
timerNo6 = timer.setInterval(offTime1 * 1000L, onOffToggler6);
isOn = false;
void onOffToggler7()
timer.deleteTimer(timerNo7);
if (!isOn)
timerNo7 = timer.setInterval(onTime2 * 1000L, onOffToggler7);
isOn = true;
timerNo7 = timer.setInterval(offTime2 * 1000L, onOffToggler7);
isOn = false;
void onOffToggler8()
timer.deleteTimer(timerNo8);
if (!isOn)
timerNo8 = timer.setInterval(onTime3 * 1000L, onOffToggler8);
isOn = true;
timerNo8 = timer.setInterval(offTime3 * 1000L, onOffToggler8);
isOn = false;
void onOffToggler9()
timer.deleteTimer(timerNo9);
if (!isOn)
timerNo9 = timer.setInterval(onTime4 * 1000L, onOffToggler9);
isOn = true;
timerNo9 = timer.setInterval(offTime4 * 1000L, onOffToggler9);
isOn = false;
void onOffToggler10()
if (!isOn)
timerNo10 = timer.setInterval(onTime5two * 1000L, onOffToggler10);
isOn = true;
timerNo10 = timer.setInterval(offTime5two * 1000L, onOffToggler10);
isOn = false;
BLYNK_WRITE(V11)
Blynk.virtualWrite(V21, finishedCycle); //write value to server
if (onState == 1)
timer.disable(timerNo11); // Turn off
timer.disable(timerNo12); // Turn off
timer.disable(timerNo13); // Turn off
timer.disable(timerNo14); // Turn off
timer.disable(timerNo15); // Turn off
onOffToggler11(); // Turn on
onOffToggler12(); // Turn on
onOffToggler13(); // Turn on
onOffToggler14(); // Turn on
onOffToggler15(); // Turn on
digitalWrite(piezoPin2, LOW);
// MCU operations
void onOffToggler11()
timer.deleteTimer(timerNo11);
if (!isOn)
// Blynk.virtualWrite(V21, finishedCycle); //write value to server
digitalWrite(piezoPin2, HIGH);
timerNo11 = timer.setInterval(onTime1 * 1000L, onOffToggler6);
isOn = true;
timerNo11 = timer.setInterval(offTime1 * 1000L, onOffToggler6);
isOn = false;
void onOffToggler12()
timer.deleteTimer(timerNo12);
if (!isOn)
timerNo12 = timer.setInterval(onTime2 * 1000L, onOffToggler12);
isOn = true;
timerNo12 = timer.setInterval(offTime2 * 1000L, onOffToggler12);
isOn = false;
void onOffToggler13()
timer.deleteTimer(timerNo13);
if (!isOn)
timerNo13 = timer.setInterval(onTime3 * 1000L, onOffToggler13);
isOn = true;
timerNo13 = timer.setInterval(offTime3 * 1000L, onOffToggler13);
isOn = false;
void onOffToggler14()
timer.deleteTimer(timerNo14);
if (!isOn)
timerNo14 = timer.setInterval(onTime4 * 1000L, onOffToggler14);
isOn = true;
timerNo14 = timer.setInterval(offTime4 * 1000L, onOffToggler14);
isOn = false;
void onOffToggler15()
timer.deleteTimer(timerNo15);
if (!isOn)
timerNo15 = timer.setInterval(onTime5three * 1000L, onOffToggler15);
isOn = true;
timerNo15 = timer.setInterval(offTime5three * 1000L, onOffToggler15);
isOn = false;
pinMode(14, OUTPUT);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
/** pinMode(12, OUTPUT);
digitalWrite(14,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
timerNo1 = timer.setInterval(onTime1 * 1000L, onOffToggler1); // Do function every 10 sec, if enabled
timer.disable(timerNo1); // start disabled
timerNo2 = timer.setInterval(onTime2 * 1000L, onOffToggler2); // Do function every 10 sec, if enabled
timer.disable(timerNo2); // start disabled
timerNo3 = timer.setInterval(onTime3 * 1000L, onOffToggler3); // Do function every 10 sec, if enabled
timer.disable(timerNo3); // start disabled
timerNo4 = timer.setInterval(onTime4 * 1000L, onOffToggler4); // Do function every 10 sec, if enabled
timer.disable(timerNo4); // start disabled
timerNo5 = timer.setInterval(onTime5 * 1000L, onOffToggler5); // Do function every 10 sec, if enabled
timer.disable(timerNo5); // start disabled
// After blynk configs etc make sure that you start off with "off state"
Blynk.virtualWrite(V0, onState);
Blynk.virtualWrite(V6, onState);
Blynk.virtualWrite(V11, onState);
Blynk.virtualWrite(V10, onState);
timerNo6 = timer.setInterval(onTime1 * 1000L, onOffToggler6); // Do function every 10 sec, if enabled
timer.disable(timerNo6); // start disabled
timerNo7 = timer.setInterval(onTime2 * 1000L, onOffToggler7); // Do function every 10 sec, if enabled
timer.disable(timerNo7); // start disabled
timerNo8 = timer.setInterval(onTime3 * 1000L, onOffToggler8); // Do function every 10 sec, if enabled
timer.disable(timerNo8); // start disabled
timerNo9 = timer.setInterval(onTime4 * 1000L, onOffToggler9); // Do function every 10 sec, if enabled
timer.disable(timerNo9); // start disabled
timerNo10 = timer.setInterval(onTime5 * 1000L, onOffToggler10); // Do function every 10 sec, if enabled
timer.disable(timerNo10); // start disabled
timerNo11 = timer.setInterval(onTime1 * 1000L, onOffToggler11); // Do function every 10 sec, if enabled
timer.disable(timerNo11); // start disabled
timerNo12 = timer.setInterval(onTime2 * 1000L, onOffToggler12); // Do function every 10 sec, if enabled
timer.disable(timerNo12); // start disabled
timerNo13 = timer.setInterval(onTime3 * 1000L, onOffToggler13); // Do function every 10 sec, if enabled
timer.disable(timerNo13); // start disabled
timerNo14 = timer.setInterval(onTime4 * 1000L, onOffToggler14); // Do function every 10 sec, if enabled
timer.disable(timerNo14); // start disabled
timerNo15 = timer.setInterval(onTime5 * 1000L, onOffToggler15); // Do function every 10 sec, if enabled
timer.disable(timerNo15); // start disabled
