Multiple Sliders and Timers
I have a slider set up with 5 different timers, depending on where (0-5) the slider is set. Not only is there a timer for the duration of the PIN being high, but also a timer that is activated that determines the duration of off (low) time before the PIN is high again. I apologize I’m sure it looks like a mess. Is there a easier way to do this? I will be having two other sliders controlling 3 pins total!
Thanks in advance!!
Daniel Kitchen
#define PIN 14
#define PIN 12
#define PIN 13
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int finishedCycle = 1;
int relayPin = 14;
int piezoPin1 = 14;
int piezoPin2 = 12;
int piezoPin3 = 13;
int timerNo1;   // ID of timer to start stop
int timerNo2;   // ID of timer to start stop
int timerNo3;   // ID of timer to start stop
int timerNo4;   // ID of timer to start stop
int timerNo5;   // ID of timer to start stop
int onState = 0; // 1 is On 0 is Off
int onTime1 = 9.5; // seconds
int offTime1  = 22.5; // seconds
int onTime2 = 12.5;
int offTime2 = 17.5;
int onTime3 = 14;
int offTime3 = 15;
int onTime4 = 18;
int offTime4 = 10;
int onTime5 = 20;
int offTime5 = 5;
int timerID = 1;
int peizoOn1;
int piezoOn2;
int piezpoOn3;
boolean isOn = false; // toggle flag for relay
BLYNK_WRITE(V19) //Refresh finishedCycle from server
  finishedCycle = param.asInt();
//first slider test!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
BLYNK_WRITE(V6)
   finishedCycle = 0;  // Sets cycle as begun
   Blynk.virtualWrite(V19, finishedCycle); //write value to server
   onState = param.asInt();
   if (onState == 1 && finishedCycle == 0)
       timer.enable(timerNo1); // Turn on
       finishedCycle++;  // Sets cycle as finished
    else if (onState == 2 && finishedCycle == 0)
       timer.enable(timerNo2); // Turn on
    else if (onState == 3 && finishedCycle == 0)
       timer.enable(timerNo3); // Turn on
    else if (onState == 4 && finishedCycle == 0)
       timer.enable(timerNo4); // Turn on
    else if (onState == 5 && finishedCycle == 0)
       timer.enable(timerNo5); // Turn on
       timer.disable(timerNo1); // Turn off
       timer.disable(timerNo2); // Turn off
       timer.disable(timerNo3); // Turn off
       timer.disable(timerNo4); // Turn off
       timer.disable(timerNo5); // Turn off
       digitalWrite(piezoPin1, LOW);
// Set button to switch mode
// MCU operations
void onOffToggler1()
   timer.deleteTimer(timerNo1);
   if (!isOn)
//       finishedCycle++;  // Sets cycle as begun
//       Blynk.virtualWrite(V19, finishedCycle); //write value to server
       digitalWrite(piezoPin1, HIGH);
       timerNo1 = timer.setInterval(onTime1 * 1000L, onOffToggler1);
       isOn = true;
//      finishedCycle = 0;  // Sets cycle as begun
      timerNo1 = timer.setInterval(offTime1 * 1000L, onOffToggler1);
      isOn = false;
void onOffToggler2()
   timer.deleteTimer(timerNo2);
   if (!isOn)
       timerNo2 = timer.setInterval(onTime2 * 1000L, onOffToggler2);
       isOn = true;
      timerNo2 = timer.setInterval(offTime2 * 1000L, onOffToggler2);
      isOn = false;
void onOffToggler3()
   timer.deleteTimer(timerNo3);
   if (!isOn)
       timerNo3 = timer.setInterval(onTime3 * 1000L, onOffToggler3);
       isOn = true;
      timerNo3 = timer.setInterval(offTime3 * 1000L, onOffToggler3);
      isOn = false;
void onOffToggler4()
   timer.deleteTimer(timerNo4);
   if (!isOn)
       timerNo4 = timer.setInterval(onTime4 * 1000L, onOffToggler4);
       isOn = true;
      timerNo4 = timer.setInterval(offTime4 * 1000L, onOffToggler4);
      isOn = false;
void onOffToggler5()
   timer.deleteTimer(timerNo5);
   if (!isOn)
       timerNo5 = timer.setInterval(onTime5 * 1000L, onOffToggler5);
       isOn = true;
      timerNo5 = timer.setInterval(offTime5 * 1000L, onOffToggler5);
      isOn = false;
  pinMode(14, OUTPUT);
/**  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(14,LOW);
  digitalWrite(12,LOW);
  digitalWrite(13,LOW);
   timerNo1 = timer.setInterval(onTime1 * 1000L, onOffToggler1); // Do function every 10 sec, if enabled
   timer.disable(timerNo1); // start disabled
   timerNo2 = timer.setInterval(onTime2 * 1000L, onOffToggler2); // Do function every 10 sec, if enabled
   timer.disable(timerNo2); // start disabled
      timerNo3 = timer.setInterval(onTime3 * 1000L, onOffToggler3); // Do function every 10 sec, if enabled
   timer.disable(timerNo3); // start disabled
      timerNo4 = timer.setInterval(onTime4 * 1000L, onOffToggler4); // Do function every 10 sec, if enabled
   timer.disable(timerNo4); // start disabled
      timerNo5 = timer.setInterval(onTime5 * 1000L, onOffToggler5); // Do function every 10 sec, if enabled
   timer.disable(timerNo5); // start disabled
   // After blynk configs etc make sure that you start off with "off state"
  Blynk.virtualWrite(V0, onState);
    Blynk.virtualWrite(V6, onState);
We have Segmented Control widget that has max of 5 options in it - it will be better to use it for your sketch than Slider that controls timers.
Where do I find this widget?
It is the last widget in the ‘Interfaces’ section
Make sure you are using latest Blynk files… App, Library and Local Server (if using one) inorder to properly use all new widgets.
Unless you’re using iOS, in which case it’s in the “Not yet implemented” section :open_mouth:
I have each slider working however they will not all three work at the same time. How do I get them to work at once? I’ve tried looking around but do not see exactly what do!
Your help is appreciated.
#define PIN 14
#define PIN 12
#define PIN 13
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int relayPin = 14; // adjust accordingly
int piezoPin1 = 14;
int piezoPin2 = 12;
int piezoPin3 = 13;
int timerNo6;
int timerNo7;
int timerNo8;
int timerNo9;
int timerNo10;
int timerNo11;
int timerNo12;
int timerNo13;
int timerNo14;
int timerNo15;
int onTime1 = 20; // seconds
//9seconds
int offTime1  = 20; // seconds
//22 seconds
int onTime2 = 15;
//12.5
int offTime2 = 15;
//3
int onTime3 = 10;
//2,5
int offTime3 = 10;
int onTime4 = 5;
int offTime4 = 5;
int onTime5 = 1;
int offTime5 = 1;
int onTime5two = 1;
int offTime5two = 1;
int onTime5three = 1;
int offTime5three = 1;
int timerID = 1;
int peizoOn1;
int piezoOn2;
int piezpoOn3;
/*BLYNK_WRITE(V19) //Refresh finishedCycle from server
BLYNK_WRITE(V6)
   if (onState == 1)
       onOffToggler1(); // Turn on
   else if (onState == 2)
          onOffToggler2(); // Turn on
   else if (onState == 3)
         onOffToggler3(); // Turn on
   else if (onState == 4)
          onOffToggler4(); // Turn on
   else if (onState == 5)
          onOffToggler5(); // Turn on
// MCU operations
   if (!isOn)
       isOn = true;
      isOn = false;
   if (!isOn)
       isOn = true;
      isOn = false;
   if (!isOn)
       isOn = true;
      isOn = false;
   if (!isOn)
       isOn = true;
      isOn = false;
   if (!isOn)
       isOn = true;
      isOn = false;
BLYNK_WRITE(V10)
   Blynk.virtualWrite(V20, finishedCycle); //write value to server
   if (onState == 1)
          timer.disable(timerNo6); // Turn off
          timer.disable(timerNo7); // Turn off
          timer.disable(timerNo8); // Turn off
          timer.disable(timerNo9); // Turn off
          timer.disable(timerNo10); // Turn off
       onOffToggler6(); // Turn on
          onOffToggler7(); // Turn on
         onOffToggler8(); // Turn on
          onOffToggler9(); // Turn on
          onOffToggler10(); // Turn on
       digitalWrite(piezoPin3, LOW);
// MCU operations
void onOffToggler6()
   timer.deleteTimer(timerNo6);
   if (!isOn)
//       Blynk.virtualWrite(V20, finishedCycle); //write value to server
       digitalWrite(piezoPin3, HIGH);
       timerNo6 = timer.setInterval(onTime1 * 1000L, onOffToggler6);
       isOn = true;
      timerNo6 = timer.setInterval(offTime1 * 1000L, onOffToggler6);
      isOn = false;
void onOffToggler7()
   timer.deleteTimer(timerNo7);
   if (!isOn)
       timerNo7 = timer.setInterval(onTime2 * 1000L, onOffToggler7);
       isOn = true;
      timerNo7 = timer.setInterval(offTime2 * 1000L, onOffToggler7);
      isOn = false;
void onOffToggler8()
   timer.deleteTimer(timerNo8);
   if (!isOn)
       timerNo8 = timer.setInterval(onTime3 * 1000L, onOffToggler8);
       isOn = true;
      timerNo8 = timer.setInterval(offTime3 * 1000L, onOffToggler8);
      isOn = false;
void onOffToggler9()
   timer.deleteTimer(timerNo9);
   if (!isOn)
       timerNo9 = timer.setInterval(onTime4 * 1000L, onOffToggler9);
       isOn = true;
      timerNo9 = timer.setInterval(offTime4 * 1000L, onOffToggler9);
      isOn = false;
void onOffToggler10()
   if (!isOn)
       timerNo10 = timer.setInterval(onTime5two * 1000L, onOffToggler10);
       isOn = true;
      timerNo10 = timer.setInterval(offTime5two * 1000L, onOffToggler10);
      isOn = false;
BLYNK_WRITE(V11)
   Blynk.virtualWrite(V21, finishedCycle); //write value to server
   if (onState == 1)
          timer.disable(timerNo11); // Turn off
          timer.disable(timerNo12); // Turn off
          timer.disable(timerNo13); // Turn off
          timer.disable(timerNo14); // Turn off
          timer.disable(timerNo15); // Turn off
       onOffToggler11(); // Turn on
          onOffToggler12(); // Turn on
         onOffToggler13(); // Turn on
          onOffToggler14(); // Turn on
          onOffToggler15(); // Turn on
       digitalWrite(piezoPin2, LOW);
// MCU operations
void onOffToggler11()
   timer.deleteTimer(timerNo11);
   if (!isOn)
//       Blynk.virtualWrite(V21, finishedCycle); //write value to server
       digitalWrite(piezoPin2, HIGH);
       timerNo11 = timer.setInterval(onTime1 * 1000L, onOffToggler6);
       isOn = true;
      timerNo11 = timer.setInterval(offTime1 * 1000L, onOffToggler6);
      isOn = false;
void onOffToggler12()
   timer.deleteTimer(timerNo12);
   if (!isOn)
       timerNo12 = timer.setInterval(onTime2 * 1000L, onOffToggler12);
       isOn = true;
      timerNo12 = timer.setInterval(offTime2 * 1000L, onOffToggler12);
      isOn = false;
void onOffToggler13()
   timer.deleteTimer(timerNo13);
   if (!isOn)
       timerNo13 = timer.setInterval(onTime3 * 1000L, onOffToggler13);
       isOn = true;
      timerNo13 = timer.setInterval(offTime3 * 1000L, onOffToggler13);
      isOn = false;
void onOffToggler14()
   timer.deleteTimer(timerNo14);
   if (!isOn)
       timerNo14 = timer.setInterval(onTime4 * 1000L, onOffToggler14);
       isOn = true;
      timerNo14 = timer.setInterval(offTime4 * 1000L, onOffToggler14);
      isOn = false;
void onOffToggler15()
   timer.deleteTimer(timerNo15);
   if (!isOn)
       timerNo15 = timer.setInterval(onTime5three * 1000L, onOffToggler15);
       isOn = true;
      timerNo15 = timer.setInterval(offTime5three * 1000L, onOffToggler15);
      isOn = false;
    Blynk.virtualWrite(V11, onState);
    Blynk.virtualWrite(V10, onState);
       timerNo6 = timer.setInterval(onTime1 * 1000L, onOffToggler6); // Do function every 10 sec, if enabled
   timer.disable(timerNo6); // start disabled
   timerNo7 = timer.setInterval(onTime2 * 1000L, onOffToggler7); // Do function every 10 sec, if enabled
   timer.disable(timerNo7); // start disabled
      timerNo8 = timer.setInterval(onTime3 * 1000L, onOffToggler8); // Do function every 10 sec, if enabled
   timer.disable(timerNo8); // start disabled
      timerNo9 = timer.setInterval(onTime4 * 1000L, onOffToggler9); // Do function every 10 sec, if enabled
   timer.disable(timerNo9); // start disabled
      timerNo10 = timer.setInterval(onTime5 * 1000L, onOffToggler10); // Do function every 10 sec, if enabled
   timer.disable(timerNo10); // start disabled
          timerNo11 = timer.setInterval(onTime1 * 1000L, onOffToggler11); // Do function every 10 sec, if enabled
   timer.disable(timerNo11); // start disabled
   timerNo12 = timer.setInterval(onTime2 * 1000L, onOffToggler12); // Do function every 10 sec, if enabled
   timer.disable(timerNo12); // start disabled
      timerNo13 = timer.setInterval(onTime3 * 1000L, onOffToggler13); // Do function every 10 sec, if enabled
   timer.disable(timerNo13); // start disabled
      timerNo14 = timer.setInterval(onTime4 * 1000L, onOffToggler14); // Do function every 10 sec, if enabled
   timer.disable(timerNo14); // start disabled
      timerNo15 = timer.setInterval(onTime5 * 1000L, onOffToggler15); // Do function every 10 sec, if enabled
   timer.disable(timerNo15); // start disabled
