I need to create 4 different projects distributed to 4 different persons, but all of these should be connected to the same single Arduino Board that will serve the 4 projects.
Some of the values will be common ones, like the humidity and the temperature but others will be private to each project.
Since i am a new to the platform , can we do this ?
Yes you can, provided that this is t a commercial project.
You can either use Bridge code (take a look at the Sketch Builder for an example) or API calls - see the documentation for the API syntax. If you do use the API then I’d suggest that you alway use the GET call even when you’re doing PUT type actions.
