Multiple PIR Sensors with Node MCU
Hi Guys,
I’m trying to get two PIR sensors to work off a single NodeMCU.
My script below keeps flooding blynk and the LED is constantly returning a HIGH value.
Any ideas would be greatly appreciated.
//#define BLYNK_DEBUG // Optional, this enables lots of prints
//#define BLYNK_PRINT Serial
char auth[] = "XXXXXX";
/* WiFi credentials */
char ssid[] = "XXXX";
char pass[] = "XXX";
#define ledPin D7
#define pirPin1 D1 // Input from PIR 1
#define pirPin2 D2 // Input from PIR 2
int pirValue1; // Place to store read PIR 1 Value
int pirValue2; // Place to store read PIR 2 Value
int pirState = LOW;
int val;
  pinMode(ledPin, OUTPUT);
  pinMode(pirPin1, INPUT);
  pinMode(pirPin2, INPUT);
  getPirValue();
void getPirValue(void)
  pirValue1 = digitalRead(pirPin1);
  pirValue2 = digitalRead(pirPin2);
  if (pirValue1 == HIGH || pirValue2 == HIGH) {
   digitalWrite(ledPin, HIGH);
    Blynk.notify("T==> Motion detected");
    if (pirState == LOW) {
     Serial.println("==> Motion detected");
     pirState = HIGH;
    digitalWrite(ledPin, LOW); // turn LED OFF
     //Blynk.notify("T==> Motion ended");
   if (pirState == HIGH){
      Serial.println("Motion ended!");
    pirState = LOW;
Putting this in your void loop() is exactly the same as having all those function commands in the loop itself, thus running thousands of times a second… use timed functions instead…
http://help.blynk.cc/getting-started-library-auth-token-code-examples/blynk-basics/how-to-display-any-sensor-data-in-blynk-app
