Hello. I have a question about using two devices on the same template. I have a template created and two devices connected. Each device has its own key (BLYNK AUTH TOKEN) and they share the same template and name (TEMPLATE ID and TEMPLATE NAME).
Both devices are on the same system, meaning they are powered on at the same time. I noticed that the first registered device connects immediately. The second one cannot connect to Blynk, remaining offline. Then, if I reset the second device, it connects without problems and both become online.
The question is: is there any problem or situation where both devices shouldnât be online at the same time? Thank you for any help.
