Curious if there is a straightforward way to use a single webhook widget to write data from multi device to a single Thingspeak channel. Right now I have a multi device project running with separate webhook widgets and Thingspeak channels for each device. It works fine, though I thought there might be a more streamlined process that I am just missing.
Thanks in advance!
It would work if you switched from multi device to bridge.
Many thanks! Just got around to switching from multi-device to bridge and it’s working a charm.
