@Tom probably poor pin selection on your part. Which did you choose and have you studied the pinout in detail?
Bad choice, GPIO 15 is part of the boot sequence, along with 0 and 2. GPIO 4 and GPIO 5 are the best pins for most requirements. Move it and see how you go.
ā¦
0.9 or 1.0?
13 and 14 would be my next choices.
@Costas i have tested without GPIO 15 instead I have used GPIO 4, and everything is working fine. Thanks for your support!
@Costas today I have buyed new energy, until jet I did not get the energy. Do you know how long it will take time?
Itās immediate, try logging out of the app and if this fails reboot the smartphone.
BlynkTimer is used to call your main functions, these functions can then call there own subroutines. Subroutines canāt really exist without the ultimate control of BlynkTimer.
@Costas i have a question, can you tell me what the problem could be if I get the following hint in the serial monitor: connection to blynk 8442 ready ping 1011ms
Thatās standard message for a successful connection. However 1011ms is much longer than it takes for most people to connect. I normally have less than 100ms. Are you getting the message over and over again or just once?
