More conditions in automation?
Hi all,
is there any way to use more conditions in automation?
my example :
if temperature is below 2 and inverter is on , check pressure. If pressure il lower than given reference, turn on the speaker.
It would be so simple…
You can do this with WHEN & DO THIS.
Did you try ?
you cannot add more conditions…
Yes, you can add one condition only.
You can easily achieve this in the sketch.
It’s a big limit.
It has no sense an automation with only 1 condition lol
You can use if statement with some global variables instead.
I know but it’s a big limit, Automations becomes useless
Actually it’s not, it’s so useful in some cases.
I was thinking this should work for your use case scenario.
This is multiple actions, not multiple conditions.
Yes, we have that in plans, at the moment it requires a lot of UI changes, so not gonna happen soon.
For business clients we have Rule Engine that has much more capabilities and allows multiple conditions in trigger as well.
