Modified the example sketch to have Blynk.virtualWrite() calls instead of terminal.***() calls. Maybe the site admin can include this in the examples sketch library. Have the older calls also commented and flagged as
/ OLDER EXAMPLE VERSION HAD THESE LINES
http://twitter.com/blynk_app
You can send/receive any data using WidgetTerminal object.
App project setup:
Terminal widget attached to Virtual Pin V1
Uses Blynk.virtualWrite calls instead of terminal.print calls
More recent implementation and hopefully more stable thus.
char pass[] = "YourPassword";
// Attach virtual serial terminal to Virtual Pin V1
WidgetTerminal terminal(V1);
// You can send commands from Terminal to your hardware. Just use
// the same Virtual Pin as your Terminal Widget
BLYNK_WRITE(V1)
// if you type "Marco" into Terminal Widget - it will respond: "Polo:"
if (String("Marco") == param.asStr()) {
Blynk.virtualWrite(V1, "You said: 'Marco'\nI said: 'Polo'\n");
/* OLDER EXAMPLE VERSION HAD THESE LINES
* terminal.println("You said: 'Marco'") ;
* terminal.println("I said: 'Polo'") ;
// Send it back
Blynk.virtualWrite(V1, "\nYou said:", param.asStr());
* terminal.print("You said:");
* terminal.write(param.getBuffer(), param.getLength());
* terminal.println();
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
Blynk.virtualWrite(V1,"Blynk v ", BLYNK_VERSION, ": Device started\n");
Blynk.virtualWrite(V1,"-------------\n");
Blynk.virtualWrite(V1,"Type 'Marco' and get a reply, or type\n");
Blynk.virtualWrite(V1,"anything else and get it printed back.\n");
* terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
* terminal.println(F("-------------"));
* terminal.println(F("Type 'Marco' and get a reply, or type"));
* terminal.println(F("anything else and get it printed back."));
* terminal.flush();
