I’ve been connecting my MKR GSM 1400 to blynk both using the blynk library/tiny gsm and also the http API. I am able to connect both ways but the connection is not stable enough to supply data for more than maximum an hour so far. What my project does is measure temperature end sending value and battery voltage.
I have connected the MKR GSM 1400 to a large LiPo battery pack. I have checked that the battery supplies the board with approx 4v on the battery connector. My question is if there is some error in my code that causes this instability or if it is more likely to be caused by battery or something else? Thanks for all feedback on this issue.
My code for Blynk library is here:
* For this example, you need to install Blynk library:
* https://github.com/blynkkk/blynk-library/releases/latest
* TinyGSM Getting Started guide:
* http://tiny.cc/tiny-gsm-readme
* Blynk supports many development boards with WiFi, Ethernet,
* GSM, Bluetooth, BLE, USB/Serial connection methods.
* See more in Blynk library examples and community forum.
* http://www.blynk.io/
* Change GPRS apm, user, pass, and Blynk auth token to run :)
#include <OneWire.h>
#define ONE_WIRE_BUS 5
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 60
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
// #define TINY_GSM_MODEM_SIM808
// #define TINY_GSM_MODEM_SIM900
#define TINY_GSM_MODEM_UBLOX
// #define TINY_GSM_MODEM_BG96
// #define TINY_GSM_MODEM_A6
// #define TINY_GSM_MODEM_A7
// #define TINY_GSM_MODEM_M590
// #define TINY_GSM_MODEM_ESP8266
// #define TINY_GSM_MODEM_XBEE
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT SerialGSM
#define BLYNK_DEFAULT_PORT 8080
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
// Your GPRS credentials
// Leave empty, if missing user or pass
const char apn[] = "netcom";
const char user[] = "";
const char pass[] = "";
const char auth[] = "XXX";
TinyGsm modem(SerialAT);
void ReadTemp(){
sensors.getTempCByIndex(0);
float h = sensors.getTempCByIndex(0);
h = h*10;
h=round(h);
float t = h;
t=t/10;
Blynk.virtualWrite(2,t);
int sensorValue = analogRead(ADC_BATTERY);
float voltage = sensorValue*(4.3/1023);
int percent=((voltage-3.6)/0.6)*100;
Blynk.virtualWrite(3,voltage);
Blynk.virtualWrite(4,percent);
// Set console baud rate
SerialMon.begin(115200);
SerialAT.begin(115200);
pinMode(GSM_DTR, OUTPUT);
digitalWrite(GSM_DTR, LOW);
delay(5);
// Turn on the GSM module by triggering GSM_RESETN pin
pinMode(GSM_RESETN, OUTPUT);
digitalWrite(GSM_RESETN, HIGH);
delay(100);
digitalWrite(GSM_RESETN, LOW);
SerialMon.println("Initializing modem...");
modem.restart();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
timer.setInterval(30000, ReadTemp);
My code for Http API:
#include <MKRGSM.h>
// Pass our oneWire reference to Dallas Temperature.
http://twitter.com/blynk_app
Project setup in the Blynk app:
Value Display widget on V2
// Blynk cloud server
const char* host = "blynk-cloud.com";
unsigned int port = 80;
// Network settings
#define PINNUMBER ""
// APN data
#define GPRS_APN "netcom" // replace your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "" // replace with your GPRS password
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// Start the GSM connection
void connectNetwork()
Serial.println("Connecting to GSM...");
bool status = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (status == false) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
status = true;
Serial.print(".");
Serial.println();
Serial.println("GSM connected");
bool httpRequest(const String& method,
const String& request,
String& response)
Serial.print(F("Connecting to "));
Serial.print(host);
Serial.print(":");
Serial.print(port);
Serial.print("... ");
if (client.connect(host, port)) {
Serial.println("OK");
Serial.println("failed");
return false;
client.print(method); client.println(F(" HTTP/1.1"));
client.print(F("Host: ")); client.println(host);
client.println(F("Connection: close"));
if (request.length()) {
client.println(F("Content-Type: application/json"));
client.print(F("Content-Length: ")); client.println(request.length());
client.println();
client.print(request);
client.println();
//Serial.println("Waiting response");
int timeout = millis() + 5000;
while (client.available() == 0) {
if (timeout - millis() < 0) {
Serial.println(">>> Client Timeout !");
client.stop();
return false;
//Serial.println("Reading response");
int contentLength = -1;
while (client.available()) {
String line = client.readStringUntil('\n');
line.trim();
line.toLowerCase();
if (line.startsWith("content-length:")) {
contentLength = line.substring(line.lastIndexOf(':') + 1).toInt();
} else if (line.length() == 0) {
break;
//Serial.println("Reading response body");
response = "";
response.reserve(contentLength + 1);
while (response.length() < contentLength && client.connected()) {
char c = client.read();
response += c;
client.stop();
return true;
void ReadTemp(){
String response;
// Send value to the cloud
// similar to Blynk.virtualWrite()
h = h*10;
h=round(h);
float t = h;
t=t/10;
Serial.print("Sending value: ");
Serial.println(t);
String putData = String("[\"") + t + "\"]";
if (httpRequest(String("PUT /") + auth + "/update/V2", putData, response)) {
if (response.length() != 0) {
Serial.print("WARNING: ");
Serial.println(response);
String putVoltage = String("[\"") + voltage + "\"]";
if (httpRequest(String("PUT /") + auth + "/update/V3", putVoltage, response)) {
String putPercent = String("[\"") + percent + "\"]";
if (httpRequest(String("PUT /") + auth + "/update/V4", putPercent, response)) {
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
delay(100);
Serial.println();
Serial.println();
connectNetwork();
// For more HTTP API, see http://docs.blynkapi.apiary.io
// Wait
