Mistmatch of values
Hi!
I am working on project using arduino UNO, ESP8266 and bylnk. In my project I am trying to measure Co2 in indoor environment using MQ135 sensor. My issue is I am getting correct values on serial monitor but wrong values on Bylnk app. I have use the widget Super Chart and Gauge. Here is my code:
Can anybody help?
Thanks in advance!
  1. You need triple backticks around your code.
  2. How have you got your gauge and superchart configured?
  3. Which value is wrong?
PPM values of measured CO2
As you’ve ignored the information about using triple backticks that was in the information provided when you created the topic, and the reminder from @JustBertC, I’ve removed your unformatted code.
Please edit your original post (using the pencil icon at the bottom of the post) and add-in your code with triple backticks at the beginning and end.
Also, if you don’t provide information about the differences between what you see in the serial monitor and what you see in the app, you probably won’t get much assistance with your problem.
