I was trying to get LCD working with V4, I also noticed that it was showing pins in use on other widgets which I thought was neat since usually you can’t reuse pins. So I possibly had it on 2 widgets at the same time due to a bug. Now the pin is missing.
When reporting issues like this, please mark OS you are using. Thanks
Of course, my bad.
IOS latest
I removed the widget i remembered it being on last, and readded it and it came back. So it was somehow still tied to that widget even though i had changed the pin to v5.
