yes phone emoticons
you can use extended ASCII code as well.
but not so nice
Yes, the only way I could code it in my IDE was like this
String Led1 = "\xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91"; // all low
String Led2 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91";
String Led3 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91";
String Led4 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91";
String Led5 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91";
String Led6 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91 \xF0\x9F\x8C\x91";
String Led7 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x91";
String Led8 = "\xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95 \xF0\x9F\x8C\x95";//all high
BLYNK_WRITE(V54) {
switch (param.asInt())
case 1: { // Item 1
Blynk.virtualWrite(V58, Led1);
break;
case 2: { // Item 2
Blynk.virtualWrite(V58, Led2);
break;
case 3: { // Item 3
Blynk.virtualWrite(V58, Led3);
break;
case 4: { // Item 4
Blynk.virtualWrite(V58, Led4);
break;
case 5: { // Item 5
Blynk.virtualWrite(V58, Led5);
break;
case 6: { // Item 6
Blynk.virtualWrite(V58, Led6);
break;
case 7: { // Item 7
Blynk.virtualWrite(V58, Led7);
break;
case 8: { // Item 8
Blynk.virtualWrite(V58, Led8);
break;
But it works great!
it works well!
I totally should have caught on sooner… as I used similar emoticon control for animated displays
PS, this is where I get my emoticon codes from…
i use a similary website.
Interesting graphical coding approach!! Thanks for sharing
