Migration Legacy -> IOT
Hi everybody
I have an app working for several years using ESP8266 and Blynk legacy
I try to migrate and I encounter some problems
I added
#define BLYNK_TEMPLATE_ID “xxxxxxxxxxxxxxxxxxxxx”
#define BLYNK_DEVICE_NAME “yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy”
#define BLYNK_AUTH_TOKEN “zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz”
at the top of my code.
Some times it works and I can connect, but some times it does not work and I have the message
invalid auth_token (the source code is unchanged)
What can happend ?
thnx
I’d suggest that you start by telling is which version of the Blynk library you have installed, what hardware and connection method you are using, and posting your sketch and your serial output.
Your sketch and serial output should be posted with triple backticks at the beginning and end so that they display correctly.
Hi Pete,
My ketch is really complicated, I cannot post it . But I have the same problem with a given example “nodemcu”
I use wifi and I downloaded the latest version of blynk
here after the sketch:
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on NodeMCU.
  Please be sure to select the right NodeMCU module
  in the Tools -> Board menu!
  For advanced settings please follow ESP examples :
   - ESP8266_Standalone_Manual_IP.ino
   - ESP8266_Standalone_SmartConfig.ino
   - ESP8266_Standalone_SSL.ino
#define BLYNK_DEBUG        // Optional, this enables more detailed prints
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "Txxxxxxxxxxxxxxxxxxxx7"
#define BLYNK_DEVICE_NAME "Commande des Volets"
#define BLYNK_AUTH_TOKEN "Azzzzzzzzzzzzzzzzzzzzzzv"
char auth[] = "here is my token";
   char ssid[]         = "Livebox-AE50";
   char pass[]     = "xxxxxxxxxxxxxxxxxxxxxxx";
 // Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
 // Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,30), 80);
and the serial output when it works is :
Connected to Livebox-AE50
IP address: 192.168.1.30
[3901]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v1.1.0 on ESP8266
 #StandWithUkraine    https://bit.ly/swua
[3912] Connecting to blynk.cloud:80
[3948] <[1D|00|01|00] here is my tocken
[3970] >[00|00|01|00|C8]
[3970] Ready (ping: 21ms).
[3970] Free RAM: 47368
and when it doesnot work
[3901]
    ___  __          __
        /___/ v0.6.1 on ESP8266
[3908] Connecting to blynk-cloud.com:80
[3941] <[1D|00|01|00] here is my tocken
[3966] >[00|00|01|00|09]
[3966] Invalid auth token
you’ll notice that in the case of not working the cloud server is wrong !
Your description of the error makes it sound as though sometimes when your device boots-up it works, and other times it doesn’t.
However, your serial output shows that you are re-compiling and re-uploading the sketch, and that sometimes Blynk library version 1.1.0 is being used and other times library version 0.6.1 is being used…
Library versions 0.6.1 and earlier were used by Legacy Blynk, and they don’t know how to handle the BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME lines of code and use these to force a connection to the new Blynk IoT servers.
Are you using two different machines to compile your code, one with Blynk library version 1.1.0 and the other with version 0.6.1 installed?
Or, have you done something weird with your Blynk library installation which has kept both versions installed on your computer?
Thank for your clue !
i checked the libaries and I found 2 Blynk Library in the arduino lib folder in the same machine.
Maybe the compiler take one or the other library
I deleted the older and recompile and run
It seems working, I will keep you informed
regards
