I’m new to Blynk. I’m not programmer. I start to learn Arduino course from Forbot. I try Blynk app and make my first project with Blynk (ESP32+DHT11) and it works great. I have also one project in Cayenne MyDevices: Raspberry Pi Zero + SDS011 sensor + BME680 sensor (Cayenne Admin help me with coding). I use old Tablet with Android 4.4.2 but last days Cayenne App stop working on that system and Blynk works great. My question is that: is it possible to change code to work also on Blynk? It’s possible to sensors send data to Cayenne and Blynk or I have to delete Cayenne lines of code and add Blynk code? I don’t want to delete Cayenne, I just want to try how will Blynk work with that sensors.
My code for SDS011:
#!/usr/bin/python -u
# coding=utf-8
# "DATASHEET": http://cl.ly/ekot
# https://gist.github.com/kadamski/92653913a53baf9dd1a8
from __future__ import print_function
import serial, struct, sys, time, json, subprocess
import cayenne.client
import time
import logging
# Cayenne authentication info. This should be obtained from the Cayenne Dashboard.
MQTT_USERNAME = "xxxxxxxxxxxxxxxxxxxxxxxxxxx"
MQTT_PASSWORD = "xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
MQTT_CLIENT_ID = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
client = cayenne.client.CayenneMQTTClient()
client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, loglevel=logging.INFO, port=8883)
# For a secure connection use port 8883 when calling client.begin:
# client.begin(MQTT_USERNAME, MQTT_PASSWORD, MQTT_CLIENT_ID, port=8883, loglevel=logging.INFO)
i=0
timestamp = 0
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
CMD_WORKING_PERIOD = 8
MODE_ACTIVE = 0
MODE_QUERY = 1
PERIOD_CONTINUOUS = 0
JSON_FILE = '/var/www/html/aqi.json'
MQTT_HOST = ''
MQTT_TOPIC = '/weather/particulatematter'
ser = serial.Serial()
ser.port = "/dev/ttyUSB0"
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
def dump(d, prefix=''):
print(prefix + ' '.join(x.encode('hex') for x in d))
def construct_command(cmd, data=[]):
assert len(data) <= 12
data += [0,]*(12-len(data))
checksum = (sum(data)+cmd-2)%256
ret = "\xaa\xb4" + chr(cmd)
ret += ''.join(chr(x) for x in data)
ret += "\xff\xff" + chr(checksum) + "\xab"
if DEBUG:
dump(ret, '> ')
return ret
def process_data(d):
r = struct.unpack('<HHxxBB', d[2:])
pm25 = r[0]/10.0
pm10 = r[1]/10.0
checksum = sum(ord(v) for v in d[2:8])%256
return [pm25, pm10]
#print("PM 2.5: {} μg/m^3 PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
def process_version(d):
r = struct.unpack('<BBBHBB', d[3:])
print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]), "OK" if (checksum==r[4] and r[5]==0xab) else "NOK"))
def read_response():
byte = 0
while byte != "\xaa":
byte = ser.read(size=1)
d = ser.read(size=9)
if DEBUG:
dump(d, '< ')
return byte + d
def cmd_set_mode(mode=MODE_QUERY):
ser.write(construct_command(CMD_MODE, [0x1, mode]))
read_response()
def cmd_query_data():
ser.write(construct_command(CMD_QUERY_DATA))
d = read_response()
values = []
if d[1] == "\xc0":
values = process_data(d)
return values
def cmd_set_sleep(sleep):
mode = 0 if sleep else 1
ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
read_response()
def cmd_set_working_period(period):
ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
read_response()
def cmd_firmware_ver():
ser.write(construct_command(CMD_FIRMWARE))
d = read_response()
process_version(d)
def cmd_set_id(id):
id_h = (id>>8) % 256
id_l = id % 256
ser.write(construct_command(CMD_DEVICE_ID, [0]*10+[id_l, id_h]))
read_response()
def pub_mqtt(jsonrow):
cmd = ['mosquitto_pub', '-h', MQTT_HOST, '-t', MQTT_TOPIC, '-s']
print('Publishing using:', cmd)
with subprocess.Popen(cmd, shell=False, bufsize=0, stdin=subprocess.PIPE).stdin as f:
json.dump(jsonrow, f)
cmd_set_sleep(0)
cmd_firmware_ver()
cmd_set_working_period(PERIOD_CONTINUOUS)
cmd_set_mode(MODE_QUERY);
while True:
client.loop()
if (time.time() > timestamp + 62):
cmd_set_sleep(0)
for t in range(15):
values = cmd_query_data();
if values is not None and len(values) == 2:
print("PM2.5: ", values[0], ", PM10: ", values[1])
time.sleep(2)
client.virtualWrite(0, values[0])
client.virtualWrite(1, values[1])
print("Going to sleep for 1 min...")
cmd_set_sleep(1)
timestamp = time.time()
My code for BME680:
#!/usr/bin/env python
import time
import bme680
import logging
time.sleep(30) #Sleep to allow wireless to connect before starting MQTT
print("""read-all.py - Displays temperature, pressure, humidity, and gas.
Press Ctrl+C to exit!
try:
sensor = bme680.BME680(bme680.I2C_ADDR_PRIMARY)
except IOError:
sensor = bme680.BME680(bme680.I2C_ADDR_SECONDARY)
# These calibration data can safely be commented
# out, if desired.
print('Calibration data:')
for name in dir(sensor.calibration_data):
if not name.startswith('_'):
value = getattr(sensor.calibration_data, name)
if isinstance(value, int):
print('{}: {}'.format(name, value))
# These oversampling settings can be tweaked to
# change the balance between accuracy and noise in
# the data.
sensor.set_humidity_oversample(bme680.OS_2X)
sensor.set_pressure_oversample(bme680.OS_4X)
sensor.set_temperature_oversample(bme680.OS_8X)
sensor.set_filter(bme680.FILTER_SIZE_3)
sensor.set_gas_status(bme680.ENABLE_GAS_MEAS)
MQTT_USERNAME = "xxxxxxxxxxxxxxxxxxxxxxxxx"
MQTT_PASSWORD = "xxxxxxxxxxxxxxxxxxxxxxxxx"
MQTT_CLIENT_ID = "xxxxxxxxxxxxxxxxxxxxxxxxxx"
i=0
timestamp = 0
print('\n\nInitial reading:')
for name in dir(sensor.data):
value = getattr(sensor.data, name)
sensor.set_gas_heater_temperature(320)
sensor.set_gas_heater_duration(150)
sensor.select_gas_heater_profile(0)
# Up to 10 heater profiles can be configured, each
# with their own temperature and duration.
# sensor.set_gas_heater_profile(200, 150, nb_profile=1)
# sensor.select_gas_heater_profile(1)
print('\n\nPolling:')
try:
while True:
client.loop()
if sensor.get_sensor_data():
output = '{0:.2f} C,{1:.2f} hPa,{2:.2f} %RH'.format(
sensor.data.temperature,
sensor.data.pressure,
sensor.data.humidity)
if sensor.data.heat_stable:
print('{0},{1} Ohms'.format(
output,
sensor.data.gas_resistance))
else:
print(output)
if (time.time() > timestamp + 10):
client.celsiusWrite(1, sensor.data.temperature)
client.hectoPascalWrite(2, sensor.data.pressure)
client.virtualWrite(3, sensor.data.humidity,"rel_hum","p")
client.virtualWrite(4, sensor.data.gas_resistance, "co","ohms")
time.sleep(1)
except KeyboardInterrupt:
pass
while True:
client.loop()
client.celsiusWrite(1, i)
client.luxWrite(2, i*10)
client.hectoPascalWrite(3, i+800)
i = i+1
Regards Przemek
