Hi @vshymanskyy
Do you have a simple version yet?
Or an ETA?
Hi @vshymanskyy ,
Please let me know on the support for ESP32 over micro python on new Blynk cloud. I am using older version of Blynk mpy library for my prototype , can that be tweaked for new cloud and template pls.
@vshymanskyy @PeteKnight , I am using the new Python Library on ESP32, presently have made my own wifi provisioning on ESP32 through web page & wifimanager for ESP32. However I am finding it difficult to handle disconnection of wifi. Can you please provide code for the same in python. The “Status” variable of “Connect” function does not give stable value.
Please help.
Thanks ,
@blynk.on("connected")
def blynk_connected(ping):
print('Blynk ready. Ping:', ping, 'ms')
@blynk.on("disconnected")
def blynk_disconnected():
print('Blynk disconnected')
These have been working perfectly for me
I have an issue with random disconnections and ssl does not work
Will post code and terminal output soon
It connects with ssl and crashes
On the disconnect I have inserted a 5 second delay and the reconnect works 90% of the time
Currently, my personal Python library was updated to support Blynk 2.0:
There’s also an initial implementation of Blynk.Edgent Dynamic Provisioning for Raspberry Pi (for advanced users)
Tested it with A9G Pudding board thru GPRS connection. From the first galnce, it does work with Blynk 2.0 in my case (except of @decorators which seems to be not supported by A9G micropython version). Very useful library, thanks.
Could you post a test code, pls? (Don’t need the whole code. Just the part which connects to the cloud 2.0) I’m having (looks like) a memory issue with the library, here is my post.
Thanks.
Hi
I am having issues with SSL
Set your ssl to insecure. This fixed my issues
Using the examples they worked for me
Using Pycom GPY
Get random disconnects every now and again
Pycom devices have tons of ram and flash
I think 8 MB of each
I thought that applied only for the ESP8266. Thank you, it worked!
` For ESP8266, you may need to disable secure connection using:
blynk = BlynkLib.Blynk('YourAuthToken', insecure=True)`
I tried the python modified library with a Rpi 4 board. It works but, I’m getting disconnections even with this code in the loop:
def runLoop():
while True:
try:
blynk.run()
timer.run()
except socket.error as e:
if(e.errno != errno.EPIPE):
t = time.ctime()
logging.error(str(t) + " err in main blynk " + e)
raise
blynk.connect()
BTW, what do you mean by
personal Python Library?
Doesn’t Blynk HQ support it?
Thanks for updating it.
On Raspberry Pi, I get the v0.2.0 which is said to be the legacy Blynk - ie old one-
Please remain on v0.2.0
for legacy Blynk. - when pip3 installing the library:
$pip3 install blynk-library-python
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting blynk-library-python
Downloading https://www.piwheels.org/simple/blynk-library-python/blynk_library_python-0.2.0-py3-none-any.whl
Installing collected packages: blynk-library-python
Successfully installed blynk-library-python-0.2.0
How to force pip3 to get the 2.0 library for Python ?
Have I missed something somewhere ?
@FCS , I used the code in by Main program on ESP32, how ever when I disconnect Wifi and then reconnect (Trying to emulate wifi disconnections), there is no response for above function codes. Can u help on how to handle the wifi disconnections. I suppose the Blynk library has no sync with Wifi connectivity.
Use if wifi disconnected. do something like this
DISCLAMER
Am not a programmer
time.sleep(5)
Blynk.connect
If wifi.connected == true:
Blynk.run
else:
wifi.connect
@Alegz how is your testing with Micropython A9G?
I got it working partially in MicroPython. However, after I insert SIM, it stop working.
I read several posts in A9G Micropython, it looks like very unstable.
@GarudaOne Currently I’m paused my experiments with A9G because I can’t get SD card work - I never seen it mounted. As for Blynk via A9G GSM - it does work. What version of MicroPython do you use? I’m work with pulkin + uPyCraft as IDE.
@Alegz I use the one by pulkin as you. I don’t know why it suddenly stop working when I insert the sim card. If I remove the SIM, i can run python script in that A9 chip normally. However, the SIM card seems t work as I can make a call to that sim from another phone.
I want to use this A9 chip for simple task(1-read i2c sensors data and 2-control relays). Due to its low cost in compared with TTGO T-Call, it is a good choice.
Try this code first:
import time
import cellular
import machine
import ntptime
machine.watchdog_on(30)
print("registering in GSM network...")
time.sleep_ms(200) #need only for serial output to be printed
while cellular.is_network_registered() == False:
time.sleep_ms(1000)
print("connecting...")
print("connected to GSM network")
print("get GPRS connection...")
try:
cellular.gprs("internet", "", "")
except Exception as e:
print('gprs exception:\n ' + repr(e))
print("get UTC...")
while time.localtime()[0] == 2017: #2017 is year in A9G module by default at start
try:
ntptime.settime()
print('ntp exception:\n ' + repr(e))
time.sleep_ms(1000)
t = time.localtime()
print("{:02d}:{:02d}:{:02d} {:02d}-{:02d}-{}".format(t[3], t[4], t[5], t[2], t[1], t[0])) #print formatted time
print("Boot done!")
Just a short test of the network. If everything is fine, you will get UTC time at your IDE serial connection input. If not - you can see where the problem is.
I’m expect, something wrong with your string:
cellular.gprs("internet", "", "") # edit this string according to your GSM network rules ("AP", "user", "password")
In the worst case your GSM operator does not support 2G devices anymore as legacy ones.
I use the Pycom GPY it is more expensive but is fully certified to be used in a product you can sell without having to get the radio part certified
PYCOM has well documented examples and just works. Global LTE cat-m support
I use it in a product im about to start selling and got my device certified for $800
It runs for 5 hours with an oled screen GPIO rs232 from a 1000ma lipo
They just work, easy to flash devices from MS VS with their own PYMAKr plugin
