It stays like this and nothing happens
19:05:35.274 -> =================== Forming a connection to Flora device ====================c4:7c:8d:6a:98:2c
19:05:35.305 ->  - Connection to Flora
Can you help me?
This is the code I’m using now:
#define BLYNK_PRINT Serial // Defines the object that is used for printing
#define BLYNK_DEBUG        // Optional, this enables more detailed prints
#include "BLEDevice.h"
#define alecrim "c4:7c:8d:6a:98:2c"
#define hortela "c4:7c:8d:6a:96:fd"
#define alface_manjericao "c4:7c:8d:6a:95:24"
#define cerejeira "c4:7c:8d:6a:93:7e"
#define serissa "c4:7c:8d:6a:94:a3"
#define jacare "c4:7c:8d:6a:93:cd"
#define BLYNK_NO_BUILTIN   // Disable built-in analog & digital pin operations
#include <Time.h>
#include <TimeLib.h>
#include "WiFi.h"
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  120        /* Time ESP32 will go to sleep (in seconds) */
BLEClient* pClient;
//WidgetBridge bridge1(V10); //Initiating Bridge Widget on V1 of Device LolinD32
//**********TOKEN (OK)**********//
char auth[] = "xxxxxxf";
//**********WIFI (OK)**********//
char ssid[] = "xxxxx";
char pass[] = "xxxxxx";
// The remote service we wish to connect to.
static BLEUUID serviceUUID("00001204-0000-1000-8000-00805f9b34fb");
// The characteristic of the remote service we are interested in.
static BLEUUID uuid_sensor_data("00001a01-0000-1000-8000-00805f9b34fb");
static BLEUUID uuid_write_mode("00001a00-0000-1000-8000-00805f9b34fb");
static BLEAddress floraAddress1(alecrim);
static BLEAddress floraAddress2(hortela);
static BLEAddress floraAddress3(alface_manjericao);
static BLEAddress floraAddress4(cerejeira);
static BLEAddress floraAddress5(serissa);
static BLEAddress floraAddress6(jacare);
static BLERemoteCharacteristic* pRemoteCharacteristic;
float temp;
float moisture;
float light;
int conductivity;
int freeHeapstart;
int freeHeapstop;
int c;
void getSensorData(BLEAddress pAddress, uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4){
  btStart();
  timer.setTimeout(30000L, deepsleep);
  Serial.print("=================== Forming a connection to Flora device ====================");
  Serial.println(pAddress.toString().c_str());
  Serial.println(" - Connection to Flora");
  if (!pClient->connect(pAddress)){
      pClient->disconnect();
      delay(500);
      Serial.println(" - Cannot connect to Flora");
      ESP.restart();
    Serial.println(" - Connected to Flora");
  // Obtain a reference to the service we are after in the remote BLE server.
  BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
  if (pRemoteService == nullptr) {
    Serial.print("Failed to find our service UUID: ");
    Serial.println(serviceUUID.toString().c_str());
    Serial.println(" - Found our service");
  pRemoteCharacteristic = pRemoteService->getCharacteristic(uuid_write_mode);
  uint8_t buf[2] = {0xA0, 0x1F};
  pRemoteCharacteristic->writeValue(buf, 2, true);
  // Obtain a reference to the characteristic in the service of the remote BLE server.
  pRemoteCharacteristic = pRemoteService->getCharacteristic(uuid_sensor_data);
  Serial.println(pRemoteService->toString().c_str());
  if (pRemoteCharacteristic == nullptr) {
    Serial.print("Failed to find our characteristic UUID: ");
    Serial.println(uuid_sensor_data.toString().c_str());
      Serial.println(" - Found our characteristic");
  // Read the value of the characteristic.
  std::string value = pRemoteCharacteristic->readValue();
  Serial.print("The characteristic value was: ");
  const char *val = value.c_str();
  Serial.print("Hex: ");
  for (int i = 0; i < 16; i++) {
    Serial.print((int)val[i], HEX);
    Serial.print(" ");
  Serial.println(" ");
  temp = (val[0] + val[1] * 256) / ((float)10.0);
  moisture = val[7];
  light = val[3] + val[4] * 256;
  conductivity = val[8] + val[9] * 256;
  char buffer[64];
  temp = float(temp);
  moisture = float(moisture);
  light = float(light);
  conductivity = float(conductivity);
  Serial.println(temp);
  Serial.print("Moisture: ");
  Serial.println(moisture);
  Serial.print("Light: ");
  Serial.println(light);
  Serial.print("Conductivity: ");
  Serial.println(conductivity);
  delay(500);
  btStop();
  delay(500);
  sendSensorData(pin1, pin2, pin3, pin4);
void sendSensorData(uint8_t pin1, uint8_t pin2, uint8_t pin3, uint8_t pin4) {
  do
  Blynk.connect();
} while (!Blynk.connected());
    //bridge1.setAuthToken("****************************");
    Blynk.virtualWrite(pin1, temp);
    Blynk.virtualWrite(pin2, moisture);
    Blynk.virtualWrite(pin3, light);
    Blynk.virtualWrite(pin4, conductivity);
    //bridge1.virtualWrite(V20, temp);
    //bridge1.virtualWrite(V21, moisture);
    Blynk.disconnect();
    WiFi.mode(WIFI_OFF);
    freeHeapstop = ESP.getFreeHeap();
    Serial.print("FREEHEAP END : ");
    Serial.println(freeHeapstop);
void getSensorData1(){
  getSensorData(floraAddress1, V6, V7, V8, V9);
  getSensorData(floraAddress2, V10, V11, V12, V13);
  getSensorData(floraAddress3, V14, V15, V16, V17);
  getSensorData(floraAddress4, V18, V19, V20, V21);
  getSensorData(floraAddress5, V22, V23, V24, V25);
  getSensorData(floraAddress6, V26, V27, V28, V29);
  ESP.restart();
void deepsleep(){
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  delay(200);
  esp_deep_sleep_start();
  Serial.println("Starting Flora client...");
  delay(500);
  BLEDevice::init("");
  pClient  = BLEDevice::createClient();
  delay(500);
  timer.setTimeout(102000L, getSensorData1);
