Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
http://twitter.com/blynk_app
This example shows how to use the Menu Widget.
App project setup:
Menu widget attached to V1 (put 3 items in it)
#define BLYNK_TEMPLATE_ID "TMPLgpg0kXdS"
#define BLYNK_DEVICE_NAME "menú test "
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "ozB4JUFrvmIZqLa3GMrliEAlTH8WxiV1";
char ssid[] = "miles_EXT";
char pass[] = "peruquest";
BLYNK_WRITE(V1) {
int choose = param.asInt();
Serial.print(choose);
switch (choose)
case 0: // Item 1
Serial.println("Item 1 selected");
break;
case 2: // Item 2
Serial.println("Item 2 selected");
break;
case 3: // Item 3
Serial.println("Item 3 selected");
break;
default:
Serial.println("Unknown item selected");
Blynk.virtualWrite(V2, choose);
WiFi.begin(ssid, pass);
unsigned long sttime1 = millis();
while (millis() - sttime1 <= 10000)
if (WiFi.status() == WL_CONNECTED) break;
yield();
Blynk.config("ozB4JUFrvmIZqLa3GMrliEAlTH8WxiV1");
Blynk.connect();
// Blynk.setProperty(V1, "labels", "label 1", "label 2", "label 3");
