Menu widget screen bug?
Happy new year to everyone and successful IOT projects! :wink:
Android Blynk IOT app.
Menu widget:
When i select a virtual stream that it’s lowest integer value is not 0 ,but lets say 1 for example, although that the value on widget’s screen on the project’s main screen is ok, when i tap to open the widget’s screen , the “dark” , “selection” value is not the one selected but the following one from the selection. I hope @Dmitriy undrestood what i am trying to say.
Thanks a lot
Hello, Happy new year.
For example. Add menu widget to device. Create datastream (virtual pin, integer, min value 0, max 1), add this datasream to menu widget. Add text to menu items. Change value by HTTP API to 1. Choose dark interface, return to device.
Did you mean it?
Add menu widget to device. Create datastream (virtual pin, integer, min value 1, max 3), add this datastream to menu widget. Add text to menu items.
eg:
1 - A
2 - B
3 - C
Select “B”
On main device screen it shows “B”
On widget’s screen that pop -ups when i press the widget it shows C selected.
That virtual pin correctly sends value “2” to device’s hardware.
@Liq
Thanks for the report. This issue will be fixed in the next version of the app.
Regards
