Menu Settings / Slider - Get/Set Index or value programmatically
Can this be done?
Set a menu item programmatically:
Blynk.setProperty(v1, "valIndex, "2"); // For a Menu
Get a menu item programmatically (getProperty it’s sad that it does not exist :frowning: ):
Blynk.getProperty(V1, "valIndex"); // For a Menu
Blynk.getProperty(V2, "value"); // For a Slider
Or else, the menu can push the value to the server every xxx ms?
Thanks :slight_smile:
You may try with Blynk.virtualWrite(V1, index). It may work. I never tried it.
Yes. See http://docs.blynk.cc/#blynk-main-operations-state-syncing
It worked! :slight_smile: Great! thanks.
