In the Menu Settings, after I add more a few items then menu still only have 2 items. Please help me, thanks.
Android or that other OS?
Try closing app and adding again, if that doesn’t fix it the old chestnut, power off wait 10s and power back up.
Thank you for your reply. I’m using Android, I have done your instructions, I also install new version but problem is not solved ! Any ideas ?
Thanks.
Hello. Please try to add a real name and not default.
OK ! Thank you very much, after add items with real name then everything is OK !
But this is still a bug . We will fix it in next release.
