Here’s the working code:
#include <PubSubClient.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//Blynk Auth
char auth[] = "";
char ssid1[] = "";
char pass[] = "";
//PubSub Stuff
const char* ssid = "";
const char* password = "";
const char* mqtt_server = "m12.cloudmqtt.com";
const int mqtt_port = 16552;
const char *mqtt_user = "";
const char *mqtt_pass = "";
const char *mqtt_client_name = "GarageMCU"; // Client connections cant have the same connection name
WiFiClient espClient;
PubSubClient client(espClient);
//Global Variables
const int openerPin = 13; //marked as D7 on the board
const int sensorPin = 12; //marked as D6 on the board
String previousTemp = "0";
int oldStatus = 2;
int masterAlarm = 0;
int scarlettAlarm = 0;
int garageAlarm = 0;
int gatesAlarm = 0;
int frontAlarm = 0;
int sliderAlarm = 0;
//Blynk Services
WidgetLCD lcd(V0);
WidgetLED frontLED(V35);
WidgetLED sliderLED(V36);
WidgetLED gatesLED(V37);
WidgetLED garageLED(V32);
WidgetLED scarlettLED(V33);
WidgetLED masterLED(V34);
WidgetLED openerLED(V10);
//Functions
void setup_wifi() {
// We start by connecting to a WiFi network
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("IP address: ");
void reconnect()
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect(mqtt_client_name, mqtt_user, mqtt_pass)) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("Device_Status", "GarageMCU Rebooted");
// ... and resubscribe
client.subscribe("Current_Temperature");
client.subscribe("Pool_Mode");
client.subscribe("Door_Status");
client.subscribe("Device_Status");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Message arrived [");
String newTopic = topic;
Serial.print(topic);
Serial.print("] ");
payload[length] = '\0';
String newPayload = String((char *)payload);
Serial.println(newPayload);
Serial.println();
if (newTopic == "Current_Temperature")
lcd.print(15, 0, "F");
lcd.print(13, 0, newPayload);
lcd.print(0,1, " ");
Blynk.virtualWrite(V24, newPayload);
if (newTopic == "Pool_Mode")
if (newPayload == "SPA")
Blynk.virtualWrite(V22, 1);
lcd.print(0, 0, "SPA ");
if (newPayload == "POOL")
Blynk.virtualWrite(V22, 0);
lcd.print(0, 0, "POOL");
if (newTopic == "Door_Status")
if(newPayload == "Garage Open")
Blynk.virtualWrite(12, "Garage Open");
if(garageAlarm == 1)
Blynk.notify("The Garage Door Has Opened");
client.publish("Alarms","Garage Alarm");
if(newPayload == "Garage Closed")
Blynk.virtualWrite(12, "Garage Closed");
if(newPayload == "Scarlett Open")
Blynk.virtualWrite(13, "Scarlett Door Open");
if(scarlettAlarm == 1)
Blynk.notify("Scarlett's Door Has Opened!");
client.publish("Alarms","Scarlett Alarm");
if(newPayload == "Scarlett Closed")
Blynk.virtualWrite(13, "Scarlett Door Closed");
Blynk.notify("Scarlett's Door Has Closed!");
if(newPayload == "Master Open")
Blynk.virtualWrite(14, "Master Door Open");
if(masterAlarm == 1)
Blynk.notify("Master Door Has Opened!");
client.publish("Alarms","Master Alarm");
if(newPayload == "Master Closed")
Blynk.virtualWrite(14, "Master Door Closed");
Blynk.notify("Master Door Has Closed!");
if(newPayload == "Zeier Gate Open")
Blynk.virtualWrite(15, "Zeier Gate Open");
if(gatesAlarm == 1)
Blynk.notify("Zeier Gate Open!");
client.publish("Alarms","Gate Alarm");
if(newPayload == "Zeier Gate Closed")
Blynk.virtualWrite(15, "Zeier Gate Closed");
if(gatesAlarm == 1)
Blynk.notify("Zeier Gate Has Closed!");
if(newPayload == "Equipment Gate Open")
Blynk.virtualWrite(15, "Equipment Gate Open");
if(gatesAlarm == 1)
Blynk.notify("Equipment Gate Open!");
if(newPayload == "Equipment Gate Closed")
Blynk.virtualWrite(15, "Equipment Gate Closed");
if(gatesAlarm == 1)
Blynk.notify("Equipment Gate Has Closed!");
if(newPayload == "Front Door Open")
Blynk.virtualWrite(16, "Front Door Open");
if(frontAlarm == 1)
Blynk.notify("Front Door Open!");
client.publish("Alarms","Front Door Alarm");
if(newPayload == "Front Door Closed")
Blynk.virtualWrite(16, "Front Door Closed");
if(frontAlarm == 1)
Blynk.notify("Front Door Closed!");
if(newPayload == "Sliding Door Open")
Blynk.virtualWrite(17, "Sliding Door Open");
if(sliderAlarm == 1)
Blynk.notify("Sliding Door Open!");
client.publish("Alarms","Slider Alarm");
if(newPayload == "Sliding Door Closed")
Blynk.virtualWrite(17, "Sliding Door Closed");
Blynk.notify("Sliding Door Has Closed!");
//Timer Functions
void getGarageDoorState()
int newStatus = digitalRead(sensorPin);
if(newStatus != oldStatus && newStatus == 1)
client.publish("Door_Status","Garage Open");
oldStatus = newStatus;
if(newStatus != oldStatus && newStatus == 0)
client.publish("Door_Status","Garage Closed");
void checkIn()
client.publish("Device_Status","Garage MCU OK!");
void alarmStatus()
if(masterAlarm == 0)
masterLED.off();
Blynk.virtualWrite(V4, 0);
masterLED.on();
Blynk.virtualWrite(V4, 1);
if(garageAlarm == 0)
garageLED.off();
Blynk.virtualWrite(V2, 0);
garageLED.on();
Blynk.virtualWrite(V2, 1);
if(gatesAlarm == 0)
gatesLED.off();
Blynk.virtualWrite(V9, 0);
if(gatesAlarm == 1)
gatesLED.on();
Blynk.virtualWrite(V9, 1);
if(frontAlarm == 0)
frontLED.off();
Blynk.virtualWrite(V8, 0);
if(frontAlarm == 1)
frontLED.on();
Blynk.virtualWrite(V8, 1);
if(sliderAlarm == 0)
sliderLED.off();
Blynk.virtualWrite(V10, 0);
sliderLED.on();
Blynk.virtualWrite(V10, 1);
if(scarlettAlarm == 0)
scarlettLED.off();
Blynk.virtualWrite(V3, 0);
scarlettLED.on();
Blynk.virtualWrite(V3, 1);
//Blynk Writes
BLYNK_WRITE(V20)
if (pinValue == 1)
if (! client.publish("Commands","Pool_Light"))
lcd.print(0,1, "Command Failed ");
lcd.print(0,1, "Pool Light Sent");
BLYNK_WRITE(V21)
if (pinValue == 1)
if (! client.publish("Commands","Spa_Light"))
lcd.print(0,1, "Spa Light Sent ");
BLYNK_WRITE(V22)
if (pinValue == 1)
if (! client.publish("Commands","SPA"))
lcd.print(0,1, "Mode: SPA Sent ");
if (pinValue == 0)
if (! client.publish("Commands","POOL"))
lcd.print(0,1, "Mode: POOL Sent");
BLYNK_WRITE(V2)
if (pinValue == 1 && garageAlarm == 0)
garageAlarm = 1;
garageLED.on();
if (pinValue == 0 && garageAlarm == 1)
garageAlarm = 0;
garageLED.off();
BLYNK_WRITE(V8)
if (pinValue == 1 && frontAlarm == 0)
frontAlarm = 1;
frontLED.on();
if (pinValue == 0 && frontAlarm == 1)
frontAlarm = 0;
frontLED.off();
BLYNK_WRITE(V9)
if (pinValue == 1 && gatesAlarm == 0)
gatesAlarm = 1;
gatesLED.on();
if (pinValue == 0 && gatesAlarm == 1)
gatesAlarm = 0;
gatesLED.off();
BLYNK_WRITE(V3)
if (pinValue == 1 && scarlettAlarm == 0)
scarlettAlarm = 1;
scarlettLED.on();
if (pinValue == 0 && scarlettAlarm == 1)
scarlettAlarm = 0;
scarlettLED.off();
BLYNK_WRITE(V10)
if (pinValue == 1 && sliderAlarm == 0)
sliderAlarm = 1;
sliderLED.on();
if (pinValue == 0 && sliderAlarm == 1)
sliderAlarm = 0;
sliderLED.off();
BLYNK_WRITE(V4)
if (pinValue == 1 && masterAlarm == 0)
masterAlarm = 1;
masterLED.on();
if (pinValue == 0 && masterAlarm == 1)
masterAlarm = 0;
masterLED.off();
BLYNK_WRITE(V7)
if (pinValue == 1)
digitalWrite(openerPin, HIGH);
openerLED.on();
delay(800);
digitalWrite(openerPin, LOW);
openerLED.off();
BLYNK_WRITE(V5)
if (pinValue == 1)
client.publish("Commands","Patio Light On");
if (pinValue == 0)
client.publish("Commands","Patio Light Off");
BLYNK_WRITE(V6)
if (pinValue == 1)
client.publish("Commands","Patio Fan On");
if (pinValue == 0)
client.publish("Commands","Patio Fan Off");
BLYNK_WRITE(V1)
if (pinValue == 1)
client.publish("Alarms","Clear Alarms");
BLYNK_WRITE(V11)
if (pinValue == 1)
garageAlarm = 1;
gatesAlarm = 1;
frontAlarm = 1;
sliderAlarm = 1;
BLYNK_WRITE(V18)
if (pinValue == 1)
masterAlarm = 0;
scarlettAlarm = 0;
garageAlarm = 0;
gatesAlarm = 0;
frontAlarm = 0;
sliderAlarm = 0;
setup_wifi();
client.setServer(mqtt_server, 16552);
client.setCallback(callback);
ArduinoOTA.setHostname("garageMCU");
ArduinoOTA.begin();
Blynk.config(auth);
pinMode(sensorPin, INPUT);
pinMode(openerPin, OUTPUT);
// timer setup in millis
timer.setInterval(1000, getGarageDoorState);
timer.setInterval(1000, alarmStatus);
timer.setInterval(60000, checkIn);
lcd.clear();
// Blynk.virtualWrite(V2, 0);
// Blynk.virtualWrite(V3, 0);
// Blynk.virtualWrite(V4, 0);
// Blynk.virtualWrite(V8, 0);
// Blynk.virtualWrite(V9, 0);
// Blynk.virtualWrite(V10, 0);
// frontLED.off();
// sliderLED.off();
// gatesLED.off();
// garageLED.off();
// scarlettLED.off();
// masterLED.off();
// openerLED.off();
Blynk.notify("Device Reboot, All Alarms Off!");
if (!client.connected())
reconnect();
client.loop();
ArduinoOTA.handle();
And the busted code:
//Blynk Auth
char auth[] = "";
char ssid1[] = "";
char pass[] = "";
//PubSub Stuff
//Global Variables
int oldStatus = 2;
int gatesAlarm = 0;
int frontAlarm = 0;
//Blynk Services
WidgetLED gateLED(V29);
WidgetLED timerLED(V38);
WidgetLED bedtimeLED(V30);
//Functions
void setup_wifi() {
Serial.println();
delay(500);
Serial.print(".");
Serial.println("");
void reconnect()
delay(5000);
Serial.print("] ");
Serial.println();
Blynk.setProperty(V24, "label", "Current Mode: SPA");
Blynk.setProperty(V24, "label", "Current Mode: POOL");
if(newPayload == "Exercise Open")
Blynk.virtualWrite(26, "Exercise Door Open");
if(newPayload == "Exercise Closed")
Blynk.virtualWrite(26, "Exercise Door Closed");
if(gatesAlarm == 1)
if(gatesAlarm == 1)
Blynk.virtualWrite(23, "Equipment Gate Open");
if(gatesAlarm == 1)
Blynk.virtualWrite(23, "Equipment Gate Closed");
if(gatesAlarm == 1)
if(frontAlarm == 1)
if(frontAlarm == 1)
//Timer Functions
client.publish("Door_Status","Garage Door Open");
client.publish("Door_Status","Garage Door Closed");
void checkIn()
void alarmStatus()
masterLED.off();
masterLED.on();
garageLED.off();
garageLED.on();
if(gatesAlarm == 0)
gateLED.off();
gatesLED.off();
if(gatesAlarm == 1)
gateLED.on();
gatesLED.on();
if(frontAlarm == 0)
frontLED.off();
if(frontAlarm == 1)
frontLED.on();
sliderLED.off();
sliderLED.on();
scarlettLED.off();
scarlettLED.on();
//Blynk Writes
BLYNK_WRITE(V20)
if (pinValue == 1)
Blynk.virtualWrite(V25, "Command Failed");
Blynk.virtualWrite(V25, " ");
Blynk.virtualWrite(V25, "Pool Light Sent");
BLYNK_WRITE(V21)
if (pinValue == 1)
Blynk.virtualWrite(V25, "Spa Light Sent");
BLYNK_WRITE(V22)
if (pinValue == 1)
Blynk.virtualWrite(V25, "Mode: SPA Sent");
if (pinValue == 0)
Blynk.virtualWrite(V25, "Mode: POOL Sent");
BLYNK_WRITE(V2)
garageAlarm = 1;
garageLED.on();
garageAlarm = 0;
garageLED.off();
BLYNK_WRITE(V8)
frontAlarm = 1;
frontLED.on();
frontAlarm = 0;
frontLED.off();
BLYNK_WRITE(V9)
gatesAlarm = 1;
gatesLED.on();
gateLED.on();
gatesAlarm = 0;
gatesLED.off();
gateLED.on();
BLYNK_WRITE(V3)
scarlettAlarm = 1;
scarlettLED.on();
scarlettAlarm = 0;
scarlettLED.off();
BLYNK_WRITE(V10)
sliderAlarm = 1;
sliderLED.on();
sliderAlarm = 0;
sliderLED.off();
BLYNK_WRITE(V4)
masterAlarm = 1;
masterLED.on();
masterAlarm = 0;
masterLED.off();
BLYNK_WRITE(V7)
if (pinValue == 1)
openerLED.on();
delay(800);
openerLED.off();
BLYNK_WRITE(V5)
if (pinValue == 1)
if (pinValue == 0)
BLYNK_WRITE(V6)
if (pinValue == 1)
if (pinValue == 0)
BLYNK_WRITE(V1)
if (pinValue == 1)
BLYNK_WRITE(V11)
if (pinValue == 1)
garageAlarm = 1;
gatesAlarm = 1;
frontAlarm = 1;
sliderAlarm = 1;
BLYNK_WRITE(V18)
if (pinValue == 1)
masterAlarm = 0;
scarlettAlarm = 0;
garageAlarm = 0;
gatesAlarm = 0;
frontAlarm = 0;
sliderAlarm = 0;
BLYNK_WRITE(V28)
if (pinValue == 1)
gatesAlarm = 1;
frontAlarm = 1;
sliderAlarm = 1;
timerLED.on();
if (pinValue == 0)
gatesAlarm = 0;
frontAlarm = 0;
sliderAlarm = 0;
timerLED.off();
BLYNK_WRITE(V19)
if (pinValue == 1)
scarlettAlarm = 1;
bedtimeLED.on();
if (pinValue == 0)
scarlettAlarm = 0;
bedtimeLED.off();
setup_wifi();
ArduinoOTA.begin();
Blynk.config(auth);
// frontLED.off();
// sliderLED.off();
// gatesLED.off();
// garageLED.off();
// masterLED.off();
// openerLED.off();
reconnect();
client.loop();
