MAP widget
Would it be possible to have a widget which transfers GPS data from cc3200 to blynk an plot them in map widget of blynk.
@Rameshkumar_S are you iOS or Android?
Android has a “Map” widget that you can see in the IDE examples.
@Costas iam using android and I just tried to compile map example which throws me the error:
Map.ino:27:33: fatal error: BlynkSimpleEthernet.h: No such file or directory
compilation terminated.
I have installed the library manually
Almost all the Blynk sketches are based on Ethernet access to the server. If you are using another method to connect you need to switch the libraries around.
It seems that I have not installed the library correctly,when i tried with wifi i receive the error:“Energia_WiFi.ino:32:36: fatal error: BlynkSimpleEnergiaWiFi.h: No such file or directory”
.Could you please give me the steps to install blynk libraries in energia
Don’t try to install them through the IDE. Manually install all 6 libraries as per the release notes at https://github.com/blynkkk/blynk-library/releases
