Making virtual LEDs work
Hey!
I am trying to make a virtual LED work, but with this code it stays on all the time. I have checked the Serial Port and know that ““TAKLYS”” actually changes, so that’s not the problem. I probably made a mistake in the Senduptime void, but there are no good examples out so i can’t really check. I’m kinda new to all this so bear with me.
void sendUptime(){ if (TAKLYS=1){ Blynk.virtualWrite(0,250); //Turn on Virtual LED on V0 }else{ Blynk.virtualWrite(0,0); //Turn off Virtual LED on V0 }}
Any suggestions?
(EDIT: I’m using arduino btw, in case that was unclear)
if (TAKLYS==1){
I would also make the 250, 255.
Hello.
Should be TAKLYS==1
@Costas @Dmitriy Oh wow, I did not see that. worked like a charm, thank you!
