Hi guys, this is one of the bluetooth starting projects, in which I’m using the program and just taking an arduino uno with a potentiometer and sending it to the according bluetooth app, and I did my research on what and how to do that. My issue is i’m trying to make one app for a hub, and another to receive notifications, or at least someway to. The end goal is trying to basically get sensor values from ports on the arduino, and they would be sent to a home hub, and the home hub, or just a device with blynk on it, has the first app, and another device has the receiving notifications app, aka your device, in which if you want specific data, and/or to be notified if the data reaches certain values, then it would do such. What I have right now is just one app to red all of that, where instead i’d want 2, 2 as i will need to use the hub in a future project. Also, I just would like to know if something such is feasible or doable and any tips on establishing something like that. Thank you all so much in advance!
#define BLYNC_DEBUG
// #define BLYNK_USE_DIRECT_CONNECT
char auth[] = "your auth token would go here,out for obvious reasons";
int loop_counter = 0;
SoftwareSerial SerialBLE(10, 11); // RX, TX
void myTimerEvent()
Blynk.virtualWrite(V5, int(analogRead(A0)));
//Serial.println(int(analogRead(A0)));
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
timer.setInterval(10000L, myTimerEvent);
if (analogRead(A0)>1000){
if (loop_counter==0) {
Blynk.notify("Sensor high ALERT: Value over 1000...");
loop_counter = 10 ;
loop_counter--;
loop_counter=0;
