Hi, let me tell you what I was working on. it’s about automating the lights in my room. Get it all working. The only drawback is that a few hours pass and the system is disconnected with the cell phone’s APP. Here I leave the programming and connections. I hope you can help me. Thanks a lot
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxx"; //WiFi que quiero conectar al Esp8266
char pass[] = "xxxxxx"; //Contraseña del WiFi
int btnPin = D2;
int RelayPin = D8;
int LM = D3;
int apagado;
void checkPhysicalButton();
int btnPinState = LOW; // ON
int RelayPinState = HIGH;
#define TURN_ON 0 // TURN_ON and TURN_OFF are defined to account for Active High relays
#define TURN_OFF 1 // Used to switch relay states
Serial.begin (9600);
pinMode(RelayPin, OUTPUT); // initialize your pin as output.
pinMode(LM, OUTPUT);
pinMode(btnPin, INPUT); // initialize your pin as input with enable internal pull-up resistor "input_pullup"
digitalWrite(RelayPin, TURN_OFF); // remain off till command is receive
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
timer.setInterval(10L, prendido);
apagado=0;
// Every time we connect to the cloud...
BLYNK_CONNECTED()
Blynk.syncVirtual(V1);
// When App button is pushed - switch the state
// Map this Virtual Pin to your Mobile Blynk apps widget.
BLYNK_WRITE(V1)
RelayPinState = param.asInt();
digitalWrite(RelayPin, RelayPinState);
if (digitalRead(btnPin) != btnPinState)
digitalWrite(btnPin,btnPinState);
btnPinState = !btnPinState;
if(RelayPinState == LOW)
digitalWrite(RelayPin,HIGH);
Blynk.virtualWrite(V1, RelayPinState);
digitalWrite(RelayPin,LOW);
RelayPinState = LOW;
BLYNK_WRITE(V2) //lectura del botón virtual V2
int pinValue = param.asInt();
if (pinValue == 1) {
digitalWrite(LM,HIGH);
else {
digitalWrite(LM,LOW);
BLYNK_WRITE(V3) //lectura del botón virtual V2
apagado=1;
else {
apagado=0;
void prendido()
if(apagado == 0)
digitalWrite(D5,LOW);
digitalWrite(D6,LOW);
digitalWrite(D7,LOW);
Blynk.run(); // Run Blynk
timer.run(); // Run SimpleTimer
Elements:
-Wemos D1
-Rele plate
-Led strip (12v)
-PC source (BCP450-OS)
-Resistance 1k
-Key switch
-TIP122 transistors
-Lamp 12v DC
-Lamp 220v AC
