Lost my "Energy"
Yesterday i update blynk on my android phone (android 6.0.1) and on my home server (debian 4.6.0).
After that i get an error “user is not registeret” at the login.
Here is my blynk.log:
2016-10-06 16:16:02.020 INFO - Using data dir ‘/tmp/blynk’
2016-10-06 16:16:02.192 INFO - Region : local
2016-10-06 16:16:02.922 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
2016-10-06 16:16:03.188 WARN - ATTENTION. Certificate /root/blynk and key /root/blynk paths not valid. Using embedded certs. This is not secure. Please replace it with
2016-10-06 16:16:03.476 WARN - ATTENTION. Server certificate paths cert : ‘/root/blynk’, key : ‘/root/blynk’ - not valid. Using embedded server certs and one way ssl.
2016-10-06 16:16:03.733 WARN - ATTENTION. Certificate /root/blynk and key /root/blynk paths not valid. Using embedded certs. This is not secure. Please replace it with
2016-10-06 16:16:03.859 WARN - ATTENTION. Certificate /root/blynk and key /root/blynk paths not valid. Using embedded certs. This is not secure. Please replace it with
2016-10-06 16:16:03.941 WARN - ATTENTION. Certificate /root/blynk and key /root/blynk paths not valid. Using embedded certs. This is not secure. Please replace it with
2016-10-06 16:16:04.076 INFO - Hardware plain tcp/ip server listening at 8442 port.
2016-10-06 16:16:04.078 INFO - Hardware SSL server listening at 8441 port.
2016-10-06 16:16:04.079 INFO - Application server listening at 8443 port.
2016-10-06 16:16:04.080 INFO - HTTP API server listening at 8080 port.
2016-10-06 16:16:04.081 INFO - HTTPS API server listening at 9443 port.
2016-10-06 16:16:04.082 INFO - HTTPS Admin UI server listening at 7443 port.
2016-10-06 16:16:04.082 INFO - Web Sockets server listening at 8082 port.
2016-10-06 16:16:04.083 INFO - Web SSL Sockets server listening at 8081 port.
2016-10-06 16:16:04.084 INFO - Mqtt hardware server listening at 8440 port.
2016-10-06 16:17:05.498 WARN - User ‘xxx.xxx@xxx.at’ not registered. /192.168.xxx.xxx:51693
The last working version of blynk that i use on my server was 0.18.1.
i opened a new account with the same username which was no problem.
After the login i saw that my bought “Energy” was gone and my projekt too.
the projekt is not the problem but i want the “Energy” back please.
Search this site for the word “pathway” and that will probably explain what happened.
Is the “Energy” lost when the *.user file is lost? It is stored per default in /tmp!
Yes. On local server you can use energy for free.
