Loop action problem
Hello!
I’m using Wemos D1 R2 and latest Blynk library and app. I am also using Arduino IDE 1.6.13. I am trying to read a button from the app, which works fine, but i want to read it continuously. Through the serial monitor i can see that the board changes modes as it should. However, even if sensors read values when we get through the first “if” states, the values do not continue to show up in serial monitor. I believe that’s happening because it is not working as a loop. Also, the relays are not working(they start as open as they should, but their state never changes), as i believe program freezes at some point.
Sorry if i have confused you, but here comes the code:
//Start of program
#include <dht11.h>
#include <Blynk.h>
#include <NewPing.h>
#define TRIGGER_PIN2 D4 // Arduino pin tied to trigger pin on the ultrasonic sensor 2.
#define ECHO_PIN2 D3     // Arduino pin tied to echo pin on the ultrasonic sensor 2.
#define MAX_DISTANCE2  23// Height of the Water Tank 2 (in centimeters).
#define DHT11_PIN D5
char auth[] = "****************";
char ssid[] = "8888";
char pass[] = "888888";
int Relay1 = D1;
int Relay2 = D2;
int val2 = 0;
int tankwater1 = 0; //water in tank 1 in liters
int tankwater2 = 0; //water in tank 2 in liters
int fieldsize1 = 0; //size of field1 in m^2
int fieldsize2 = 0; //size of field2 in m^2
int sensor_pin =D6;
NewPing sonar2(TRIGGER_PIN2, ECHO_PIN2, MAX_DISTANCE2); // NewPing setup of pins and maximum distance.
  Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  pinMode(Relay1, OUTPUT); //Setup Relay pin as output pin
  pinMode(Relay2, OUTPUT); //Setup Relay pin as output pin
  //pinMode(led_pin, OUTPUT);
  pinMode(sensor_pin, INPUT);
  digitalWrite(Relay1, LOW);
  digitalWrite(Relay2, LOW);
BLYNK_READ(V5)
Blynk.virtualWrite(8,val2);// virtualpin 8 distance
 BLYNK_WRITE(V1) {
  int pinValue = param.asInt();
  val2 = sonar2.convert_cm(sonar2.ping_median());
  if (pinValue==0)
    Serial.println("Irrigation mode is active");
    Serial.println("Water level is at:");
    Serial.println(23-val2);
    if(digitalRead(sensor_pin) == HIGH)
       if (val2 <= 15) //Water level reaches the Top of the Tank2
          digitalWrite(Relay2, HIGH); //Pump2 off
          delay(500);
        else if (val2 > 15) // Water is empty on the Tank2
          digitalWrite(Relay2, LOW); // Pump2 ON
          delay(500);
          //delay(86400000); one day delay. not suitable for experiment
     else if(digitalRead(sensor_pin) == LOW)
  else {
    Serial.println("Fertilize mode is active. This does nothing now");
    //val3 = sonar2.convert_cm(sonar2.ping_median());
    //tankwater2 = (10-val3)*fieldsize2; //calculation of water in tank2
//End of program
So the part you want to happen regularly should be inside the loop() {...} method.
Something like this:
int mode = 0; //0 = irrigation, 1 = fertilisation
BLYNK_WRITE(v1) {
  mode = pinValue; //store the mode, we need it inside loop()
  if(mode == 0)  {
    [...] //all the stuff you have already
  else {
@Gaff no, that is asking for problems in the long run. Loop() should only contain timer.run and Blynk.run. The way it is on the posted code is just fine.
The only thing I’m missing in the code is a function to be executed on a timely basis. E.g. like in the PushData example of Blynk. Move all the code you want to execute regularly (like say every 1s) to it’s own void functionSomething() and have that on a timer.
Maybe something like this, no guarantees it will work like you want it:
boolean tankFull = true;  // start as if tank is full so pump doesn't start running on boot/restart
BLYNK_WRITE(V1) {
  if (pinValue==0)
    NewTimer = timer.setInterval(1000L, repeatMe); //REPEAT THIS FUNCTION EVERY 1 SECOND
  else {
    timer.disable(NewTimer); //STOP THE TIMER REPEATING repeatMe FUNCTION
    digitalWrite(Relay2, HIGH); //make sure Pump2 is off; otherwise pump may continue to run if V1 goes high while pump is on
  void repeatMe()
   val2 = sonar2.convert_cm(sonar2.ping_median()); //get water level
   Blynk.virtualWrite(8,val2); // write water level to virtual pin 8
       if (val2 <= 15) //Water level has reached the Top of the Tank2
          if (tankFull != true)
          tankFull = true;
            tankFull = false;
            digitalWrite(Relay2, HIGH); //Pump2 off; otherwise pump will continue to run if sensor_pin goes low while pump is on
Remove this
BLYNK_READ(V5)
And Change
to
digitalWrite(Relay2, HIGH);// no pump upon startup
