Login timout/ Unable to connect to Blynk server
I have Satellite internet service, pings are slow…
Pinging cloud.blynk.cc [45.55.195.102] with 32 bytes of data:
Reply from 45.55.195.102: bytes=32 time=996ms TTL=52
Reply from 45.55.195.102: bytes=32 time=702ms TTL=52
Reply from 45.55.195.102: bytes=32 time=2252ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1478ms TTL=52
Reply from 45.55.195.102: bytes=32 time=794ms TTL=52
Reply from 45.55.195.102: bytes=32 time=989ms TTL=52
Reply from 45.55.195.102: bytes=32 time=614ms TTL=52
Reply from 45.55.195.102: bytes=32 time=927ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1194ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1262ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1325ms TTL=52
Reply from 45.55.195.102: bytes=32 time=995ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1061ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1075ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1087ms TTL=52
Reply from 45.55.195.102: bytes=32 time=715ms TTL=52
Reply from 45.55.195.102: bytes=32 time=1315ms TTL=52
Reply from 45.55.195.102: bytes=32 time=712ms TTL=52
Reply from 45.55.195.102: bytes=32 time=837ms TTL=52
Reply from 45.55.195.102: bytes=32 time=920ms TTL=52
Reply from 45.55.195.102: bytes=32 time=954ms TTL=52
On Satellite, most of the time I either get login timeouts or repeated attempts to connect to cloud.blynk.cc with no luck. It occasionally works for short periods of time, but that is a rare surprise.
If I try on faster internet connection, things work ok, but I can only do this to test, not normal use.
Any suggestions? Maybe a timeout increase?
I tried increasing #define BLYNK_TIMEOUT_MS 2000UL in BlynkConfig.h up to 30000UL.
That didn’t seem to help.
Thanks for the hep,
John
Hello. Could you please try local server to check if problem goes away?
Hey @John , is it working?
Thank you for reply/ suggestion. Yes, problem goes away with local server. Ideally, I would like for it to work on cloud server so I can control from outside my private network.
Thank you for the help. I understand if we can’t make it work on cloud server over my slow connection,
  • John
If you have static IP you could setup port forwarding and your server will be accessible from outside private network.
@vshymanskyy is there any way to increase connection timeout?
Thanks for the port forwarding suggestion. Unfortunately, my ISP (Hughes net) has me behind a Double NAT/ CGN and doesn’t forward any ports. I have talked with them and they don’t offer any solutions.
I have been keeping an eye out for a free/ reasonably priced cloud based VPN solution.
  • John
