Blynk Library: v 0.6.1
Os: Android 8.0
Mobile: Huawei Y5
Board: Arduino Uno R3
Bluetooth Module: Hc-05
I am making a Football Playing Robot, i am controlling three servo’s , 1x 180 degree servo used for kicking the ball, 2x 360 degree servo as wheels. The problem are as mentioned in the topic frequent timeouts but sometimes the code does work smoothly, but often there are timeouts and package too big errors.
I believe it is due to alot of code being written in the blynk write (V1). Further detail’s are written in code.
// Note To Tester
// 1. Read void setup() first before going to code.
// 2. The code is implemented using hc 05 on arduino uno.
// 3. The app used is Blynk , which is available on android, the reason for selection is that joystick and buttons are both present
// 4. For Testing Only Kicker Servo Is Attached Whose Behaviour Is Monitored, The left and right servo's are only for stub testing and are not attached.
// 5. BLYNK_WRITE() is used to read data from buttons and sensors in blynk app, the paramter is the digital pin assigned to the button/joystick/sensor
// 6. BLYNK_WRITE() programs run parallel with each other
// 7. Errors Occuring Are Login Timeout, Packet too big , disconnecting and reconnecting of hc 05
#include <Servo.h>
SoftwareSerial MyBlue(5, 6); // RX | TX
char auth[]= "9Itekdu3vf_B_3YmNxxHu9G3Bs_1IWs9";
Servo myservoKICKER; //responsible for kicking the ball, can only move 180 degree
Servo myservoLEFTWHEEL;
Servo myservoRIGHTWHEEL; // left and right 360 degree countinuos rotation servo's that act as wheels
int xAxis; //x-axis of joystick
int yAxis; //y-axis of joystick
BLYNK_WRITE(V1) // These are virtual pins which are connected to joystick in the blynk app
xAxis =param[0].asInt();
yAxis= param[1].asInt();
Serial.print("X = ");
Serial.print(xAxis);
Serial.print("Y = ");
Serial.println(yAxis);
// The values of x-axis and y-axis of joystick determines how the left and right wheel would move
if (xAxis > 400 && xAxis < 600 && yAxis > 400 && yAxis < 600)
myservoLEFTWHEEL.detach();
myservoRIGHTWHEEL.detach();
myservoKICKER.detach();
// FORWARDS FAST
else if (xAxis > 400 && xAxis < 600 && yAxis > 1018 && yAxis <= 1023)
myservoLEFTWHEEL.attach(9);
myservoRIGHTWHEEL.attach(10);
myservoLEFTWHEEL.write (180);
myservoRIGHTWHEEL.write (0);
// BACKWARDS FAST
else if (xAxis > 400 && xAxis < 600 && yAxis >= 0 && yAxis < 5)
myservoLEFTWHEEL.write (0);
myservoRIGHTWHEEL.write (180);
// LEFT FAST
else if (xAxis >= 0 && xAxis < 5 && yAxis > 400 && yAxis < 600)
// RIGHT FAST
else if (xAxis > 1018 && xAxis <= 1023 && yAxis > 400 && yAxis < 600)
// FORWARDS MEDIUM
else if (xAxis > 400 && xAxis < 600 && yAxis > 750 && yAxis < 1018)
myservoLEFTWHEEL.write (110);
myservoRIGHTWHEEL.write (70);
// BACKWARDS MEDIUM
else if (xAxis > 400 && xAxis < 600 && yAxis > 5 && yAxis < 250)
myservoLEFTWHEEL.write (70);
myservoRIGHTWHEEL.write (110);
// LEFT MEDIUM
else if (xAxis > 5 && xAxis < 250 && yAxis > 400 && yAxis < 600)
// RIGHT MEDIUM
else if (xAxis > 750 && xAxis < 1018 && yAxis > 400 && yAxis < 600)
// FORWARDS SLOW
else if (xAxis > 400 && xAxis < 600 && yAxis > 600 && yAxis < 750)
myservoLEFTWHEEL.write (100);
myservoRIGHTWHEEL.write (80);
// BACKWARDS SLOW
else if (xAxis > 400 && xAxis < 600 && yAxis > 250 && yAxis < 400)
myservoLEFTWHEEL.write (80);
myservoRIGHTWHEEL.write (100);
// LEFT SLOW
else if (xAxis > 250 && xAxis < 400 && yAxis > 400 && yAxis < 600)
// RIGHT SLOW
else if (xAxis > 600 && xAxis < 750 && yAxis > 400 && yAxis < 600)
// FORWARDS LEFT FAST
else if (xAxis >= 0 && xAxis < 5 && yAxis > 1018 && yAxis <= 1023)
myservoLEFTWHEEL.write (115);
// FORWARDS RIGHT FAST
else if (xAxis > 1018 && xAxis <= 1023 && yAxis > 1018 && yAxis <= 1023)
myservoRIGHTWHEEL.write (65);
// BACKWARDS LEFT FAST
else if (xAxis >= 0 && xAxis < 5 && yAxis >= 0 && yAxis < 5)
myservoLEFTWHEEL.write (65);
// BACKWARDS RIGHT FAST
else if (xAxis > 1018 && xAxis <= 1023 && yAxis >= 0 && yAxis < 5)
myservoRIGHTWHEEL.write (115);
// FORWARDS LEFT MEDIUM
else if (xAxis > 5 && xAxis < 400 && yAxis > 600 && yAxis < 1018)
myservoLEFTWHEEL.write (105);
// FORWARDS RIGHT MEDIUM
else if (xAxis > 600 && xAxis < 1018 && yAxis > 600 && yAxis < 1018)
myservoRIGHTWHEEL.write (75);
// BACKWARDS LEFT MEDIUM
else if (xAxis > 5 && xAxis < 400 && yAxis > 5 && yAxis < 400)
myservoLEFTWHEEL.write (75);
// BACKWARDS RIGHT MEDIUM
else if (xAxis > 600 && xAxis < 1018 && yAxis > 5 && yAxis < 400)
myservoRIGHTWHEEL.write (105);
BLYNK_WRITE(V2){ // Fast Kicker Button: Responsible to move kicker servo 180 degree at a high speed
int FastKick= param.asInt(); // Pressing This Button Sends 1 To Fast Kick Variable
Serial.print(FastKick);
if(FastKick == 1)
myservoKICKER.attach(11);
delay(100);
myservoKICKER.write (90);
delay(200);
myservoKICKER.write (160);
delay(200);
BLYNK_WRITE(V3) { // kicker calibration button: used to calibrate kicker servo to exactly 90 degree's
int KickerCalibration= param.asInt();
if(KickerCalibration == 1) // Pressing This Button Sends 1 To Kicker Calibration Variable
delay(100);
delay(200);
BLYNK_WRITE(V4) { //Used To Calibrate Left And Right Wheels
int WheelCalibration= param.asInt();
if(WheelCalibration == 1) // Pressing This Button Sends 1 To Kicker Calibration Variable
myservoLEFTWHEEL.attach(2);
myservoRIGHTWHEEL.attach(3);
delay(100);
myservoLEFTWHEEL.write (90);
myservoRIGHTWHEEL.write (90);
delay(30000);
myservoLEFTWHEEL.attach(9); //1
myservoRIGHTWHEEL.attach(10); //2
myservoKICKER.attach(11); //3
// detach servos to avoid jitter on power up
MyBlue.begin(9600); // Default communication rate of the Bluetooth module
Blynk.begin(MyBlue, auth);
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
