wanted to ask why the log events doesn’t work with blynk 2.0 I followed the instructions Log Events - Blynk Documentation but nothing happens in my blyn console timeline here is mine code
#define BLYNK_TEMPLATE_ID "vvvv"
#define BLYNK_DEVICE_NAME "bbbb"
#define BLYNK_AUTH_TOKEN "nhnz";
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
//#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
int value = 0;
int sensorValue1 = 0;
int sensorPin1 = 0;
int some_condition = 0;
delay(100);
timer.setInterval(2000L, Messungbox);
Blynk.logEvent("wasser", "Hello World,") ;
BlynkEdgent.begin();
void Messungbox(){
sensorValue1 = analogRead(sensorPin1);
Blynk.virtualWrite(V1, sensorValue1);
if(sensorValue1>1011){
Blynk.setProperty(V1, "color", "#F6070F");
BlynkEdgent.run();
This one won’t work, because it’s being called before the device is connected to the Blynk server.
It would also be helpful to see how your event is configured in the console, and to see some information about whether the if statement in Messungbox is ever evaluating to true.
@markop please don’t post the same issue in two different topics, it gets very messy when people respond in two different places.
I’ve merged everything into this topic, I’d suggest that you focus on providing the information I asked for earlier.
@PeteKnight the code is correct I deleted everything again, new board made new instructions and all of a sudden it works, I don’t understand the main thing is that it works now
