Hi
My Phone updated the client today and now I have an issue with the server version being out of date.
I have downloaded the latest version but the app cannot find the server. Using the web admin page any version above 0.15.3 has either a empty or missing user (I assume this is way it does not work)
Any and all ideas are welcome to help resolve this issue If all else fails I will have to go back to the older client on my phone (Android)
Hi
With version 0.20.1 I see the error below
"2016-12-12 07:38:05.223 INFO - Using data dir ‘\BlynkServer’
2016-12-12 07:38:05.317 INFO - Region : local
2016-12-12 07:38:06.286 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
2016-12-12 07:38:06.677 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
2016-12-12 07:38:07.224 WARN - ATTENTION. Server certificate paths cert : ‘C:\BlynkServer’, key : ‘C:\BlynkServer’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
2016-12-12 07:38:08.021 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
2016-12-12 07:38:08.443 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
2016-12-12 07:38:08.708 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
2016-12-12 07:38:09.224 INFO - Hardware plain tcp/ip server listening at 8442 port.
2016-12-12 07:38:09.224 INFO - Hardware SSL server listening at 8441 port.
2016-12-12 07:38:09.224 INFO - Application server listening at 8443 port.
2016-12-12 07:38:09.224 INFO - HTTP API server listening at 8080 port.
2016-12-12 07:38:09.239 INFO - HTTPS API server listening at 9443 port.
2016-12-12 07:38:09.239 INFO - HTTPS Admin UI server listening at 7443 port.
2016-12-12 07:38:09.239 INFO - Web Sockets server listening at 8082 port.
2016-12-12 07:38:09.239 INFO - Web SSL Sockets server listening at 8081 port.
2016-12-12 07:38:09.239 INFO - Mqtt hardware server listening at 8440 port.
2016-12-12 07:38:27.966 WARN - User ‘jman@jman.net.nz’ not registered. /192.168.0.100:54871
With version 0.15.3
“07:40:35.956 INFO - Using data dir ‘\path’
07:40:36.628 INFO - Initializing mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
07:40:37.081 INFO - Plain tcp/ip hardware server port 8442.
07:40:37.081 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
07:40:37.753 INFO - SSL hardware port 8441.
07:40:37.769 WARN - ATTENTION. Server certificate paths cert : ‘C:\BlynkServer’, key : ‘C:\BlynkServer’ - not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
07:40:38.503 INFO - Application server port 8443.
07:40:38.519 INFO - HTTP API port 8080.
07:40:38.519 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
07:40:38.769 INFO - HTTPS API port 9443.
07:40:38.785 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
07:40:39.488 INFO - HTTPS admin UI port 7443.
07:40:39.581 INFO - HTTP reset pass port 7444.
07:40:39.581 INFO - Web Sockets port 8082.
07:40:39.581 WARN - ATTENTION. Certificate C:\BlynkServer and key C:\BlynkServer paths not valid. Using embedded certs. This is not secure. Please replace it with your own certs.
07:40:39.847 INFO - Web SSL Sockets port 8081.
07:40:41.300 INFO - jman@jman.net.nz hardware joined.
07:40:42.629 INFO - jman@jman.net.nz hardware joined.
07:40:56.442 INFO - jman@jman.net.nz app joined.”
