Hi all!
I have Raspberry Pi 3 as server, download latest server version server-0.28.5-java8.jar
When I start server have next error message:
pi@rpi:~/Blynk $ java -jar server-0.28.5-java8.jar -dataFolder /home/pi/Blynk &
[1] 2116
pi@rpi:~/Blynk $ 2017-11-15 19:36:34,628 main ERROR RollingFileManager (/postgres.log) java.io.FileNotFoundException: /postgres.log (Отказано в доступе) java.io.FileNotFoundException: /postgres.log (Отказано в доступе)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.<init>(FileOutputStream.java:213)
at java.io.FileOutputStream.<init>(FileOutputStream.java:133)
at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:640)
at org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory.createManager(RollingFileManager.java:608)
at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:113)
at org.apache.logging.log4j.core.appender.OutputStreamManager.getManager(OutputStreamManager.java:115)
at org.apache.logging.log4j.core.appender.rolling.RollingFileManager.getFileManager(RollingFileManager.java:188)
at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:144)
at org.apache.logging.log4j.core.appender.RollingFileAppender$Builder.build(RollingFileAppender.java:60)
at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:122)
at org.apache.logging.log4j.core.config.AbstractConfiguration.createPluginObject(AbstractConfiguration.java:958)
at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:898)
at org.apache.logging.log4j.core.config.AbstractConfiguration.createConfiguration(AbstractConfiguration.java:890)
at org.apache.logging.log4j.core.config.AbstractConfiguration.doConfigure(AbstractConfiguration.java:513)
at org.apache.logging.log4j.core.config.AbstractConfiguration.initialize(AbstractConfiguration.java:237)
at org.apache.logging.log4j.core.config.AbstractConfiguration.start(AbstractConfiguration.java:249)
at org.apache.logging.log4j.core.LoggerContext.setConfiguration(LoggerContext.java:545)
at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:617)
at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:634)
at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:229)
at org.apache.logging.log4j.core.async.AsyncLoggerContext.start(AsyncLoggerContext.java:76)
at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:242)
at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:45)
at org.apache.logging.log4j.LogManager.getContext(LogManager.java:174)
at cc.blynk.utils.LoggerUtil.changeLogLevel(LoggerUtil.java:48)
at cc.blynk.utils.LoggerUtil.configureLogging(LoggerUtil.java:38)
at cc.blynk.server.launcher.ServerLauncher.main(ServerLauncher.java:83)
2017-11-15 19:36:34,674 main ERROR Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/postgres.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@c1670b[pattern=/archive/postgres.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{HH:mm:ss.SSS} - %msg%n, filePermissions=null, fileOwner=null]] java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/postgres.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@c1670b[pattern=/archive/postgres.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{HH:mm:ss.SSS} - %msg%n, filePermissions=null, fileOwner=null]]
at org.apache.logging.log4j.core.appender.AbstractManager.getManager(AbstractManager.java:115)
2017-11-15 19:36:34,719 main ERROR Unable to invoke factory method in class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender
at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.findFactoryMethod(PluginBuilder.java:229)
at org.apache.logging.log4j.core.config.plugins.util.PluginBuilder.build(PluginBuilder.java:134)
2017-11-15 19:36:34,737 main ERROR RollingFileManager (/stats.log) java.io.FileNotFoundException: /stats.log (Отказано в доступе) java.io.FileNotFoundException: /stats.log (Отказано в доступе)
2017-11-15 19:36:34,744 main ERROR Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/stats.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@d8062c[pattern=/archive/stats.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%msg%n, filePermissions=null, fileOwner=null]] java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/stats.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@d8062c[pattern=/archive/stats.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%msg%n, filePermissions=null, fileOwner=null]]
2017-11-15 19:36:34,751 main ERROR Unable to invoke factory method in class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender
2017-11-15 19:36:34,768 main ERROR RollingFileManager (/blynk.log) java.io.FileNotFoundException: /blynk.log (Отказано в доступе) java.io.FileNotFoundException: /blynk.log (Отказано в доступе)
2017-11-15 19:36:34,775 main ERROR Could not create plugin of type class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/blynk.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@1fbf16f[pattern=/archive/blynk.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{HH:mm:ss.SSS} %-5level- %msg%n, filePermissions=null, fileOwner=null]] java.lang.IllegalStateException: ManagerFactory [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$RollingFileManagerFactory@7d1d39] unable to create manager for [/blynk.log] with data [org.apache.logging.log4j.core.appender.rolling.RollingFileManager$FactoryData@1fbf16f[pattern=/archive/blynk.log.%d{yyyy-MM-dd}, append=true, bufferedIO=true, bufferSize=8192, policy=CompositeTriggeringPolicy(policies=[TimeBasedTriggeringPolicy(nextRolloverMillis=0, interval=1, modulate=false)]), strategy=DefaultRolloverStrategy(min=1, max=7, useMax=true), advertiseURI=null, layout=%d{HH:mm:ss.SSS} %-5level- %msg%n, filePermissions=null, fileOwner=null]]
2017-11-15 19:36:34,781 main ERROR Unable to invoke factory method in class org.apache.logging.log4j.core.appender.RollingFileAppender for element RollingFile: java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender java.lang.IllegalStateException: No factory method found for class org.apache.logging.log4j.core.appender.RollingFileAppender
2017-11-15 19:36:34,788 main ERROR Null object returned for RollingFile in Appenders.
2017-11-15 19:36:34,790 main ERROR Null object returned for RollingFile in Appenders.
2017-11-15 19:36:34,793 main ERROR Null object returned for RollingFile in Appenders.
2017-11-15 19:36:34,795 main ERROR Null object returned for RollingFile in Appenders.
2017-11-15 19:36:34,898 main ERROR Unable to locate appender "userLog" for logger config "root"
2017-11-15 19:36:34,900 main ERROR Unable to locate appender "statsLog" for logger config "cc.blynk.server.workers.StatsWorker"
2017-11-15 19:36:34,902 main ERROR Unable to locate appender "workersLog" for logger config "cc.blynk.server.workers"
2017-11-15 19:36:34,904 main ERROR Unable to locate appender "postgresDBLog" for logger config "cc.blynk.server.db"
Blynk Server 0.28.4-SNAPSHOT successfully started.
All server output is stored in folder '/home/pi/Blynk' file.
Generating own initial certificates...
Error during certificate generation.
Network error
And server not work.
