Hy guys!
I have a big problem with my project and I hope you can help me!
Hardware: Arduino Pro Mini + Sim800L + Battery
Info: “Local Server and app works fine for my other projects. (Arduinu UNO + Ethernet-Shild)”
I want to send Temp, Hum to my local blynk server, installed on a raspi!
Info: Sketch works fine with blynk cloud!
But if I use Local Blynk Server I get following information:
Modem init...
Connecting to network...
Network: T-Mobile A
Connecting to XXX
Connected to GPRS
Connecting to blynk-cloud.com:80
Invalid auth token
Sketch below:
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = "c5742898aa524b36b42ffe3d5f09695";
//char auth[] = "abd55e74180d4be8b2738e694dc66282";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "XXX.ddns.net";
char user[] = "";
char pass[] = "";
#include <SoftwareSerial.h>
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
#include <Vcc.h>
const float VccMin = 3.3; // Minimum expected Vcc level, in Volts.
const float VccMax = 4.1; // Maximum expected Vcc level, in Volts.
const float VccCorrection = 1.0/1.018; // Measured Vcc by multimeter divided by reported Vcc
Vcc vcc(VccCorrection);
int i = 0;
#include <avr/sleep.h>
volatile int sleepcounter = 0; // Schlafzyklen mitzählen
int k=0;
#include <DHT.h>
#define DHTPIN 5 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature
pinMode(6, OUTPUT);
// Set GSM module baud rate
SerialAT.begin(9600);
delay(3000);
// Restart takes quite some time
// To skip it, call init() instead of restart()
Serial.println("Initializing modem...");
digitalWrite(6, HIGH);
Serial.println("Setup High");
delay(15000);
modem.restart();
// Unlock your SIM card with a PIN
modem.simUnlock("2322");
Blynk.begin(auth, modem, apn, user, pass);
dht.begin();
watchdogOn(); // Watchdog timer einschalten.
// ADCSRA = ADCSRA & B01111111; // ADC abschalten, ADEN bit7 zu 0
ACSR = B10000000; // Analogen Comparator abschalten, ACD bit7 zu 1
DIDR0 = DIDR0 | B00111111; // Digitale Eingangspuffer ausschalten, analoge Eingangs Pins 0-5 auf
delay(2000);
// if(Blynk.connected())
// Blynk.run();
// Serial.println("Blynk.run");
// else
Serial.println("Loop HIGH");
delay(20000);
modem.restart();
delay(10000);
float p = 0.0;
float v = 0.0;
v = vcc.Read_Volts();
p = vcc.Read_Perc(VccMin, VccMax);
Blynk.virtualWrite(V0, v);
Blynk.virtualWrite(V1, p);
Blynk.virtualWrite(V2, i);
Serial.println(i);
i++;
delay(2000);
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
//Print temp and humidity values to serial monitor
Serial.print("Humidity: ");
Serial.print(hum);
Serial.print(" %, Temp: ");
Serial.print(temp);
Serial.println(" Celsius");
Blynk.virtualWrite(V3, hum);
Blynk.virtualWrite(V4, temp);
delay(2000); //Delay 2 sec.
delay(10000);
digitalWrite(6, LOW);
Serial.println("Loop LOW");
delay(1000);
Serial.println("PWR D");
delay(1000);
pwrDown(600);
void pwrDown(int sekunden)
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // den tiefsten Schlaf auswählen PWR_DOWN
for(int i=0; i < sekunden; i++) {
sleep_enable(); // sleep mode einschalten
sleep_mode(); // in den sleep mode gehen
sleep_disable(); // sleep mode ausschalten nach dem Erwachen
void watchdogOn()
MCUSR = MCUSR & B11110111; // Reset flag ausschalten, WDRF bit3 vom MCUSR.
WDTCSR = WDTCSR | B00011000; // Bit 3+4 um danach den Prescaler setzen zu können
WDTCSR = B00000110; // Watchdog Prescaler auf 128k setzen > ergibt ca. 1 Sekunde
WDTCSR = WDTCSR | B01000000; // Watchdog Interrupt einschalten
ISR(WDT_vect) {
sleepcounter ++; // Schlafzyklen mitzählen
I think I have some troubles with Blynk.begin() and hope someone can help me!
Thanks!
