Local server not sending CSV files from charts or Superchars=ts [SOLVED]
[SOLVED:
administration.https.port=7443
**CHANGED** to:
administration.https.port=9443
hi @Dmitriy
My local server send email notifications from within Sketch(s) and also when I create a new Sketch it correctly sends new Auth code via email account as setup in mail.properties but when I ask app to send CSV file of graph from my normal Chart to SuperChart I receive nothing. Any clues as to why that may be the case ? I’m using local server 0.33.2.
Those property are no longer used. So I don’t think it solved your issue. Probably you just updated server?
mmm no didn’t do anything else really just started to work again. Must admit I tried it from IOS client first and wasn’t working then I tried it on Android client and it worked first time ! Then iOS started to work again. I might be clutching at straws but apart from crossing my fingers nothing else I did differently :wink:
