Local server and USB as possible?
I see no symbol to put my code in the message?
And you don’t have an ETHERNET card for the UNO, right?
not only uno
Not easy to have to work with google translator
OK so ignore all @castle’s reference’s to IP, dns, gateway, MAC, etc, etc as he was wrongly providing you with an Ethernet sketch.
You were nearly there with the proper USB sketch until you went off on a tangent.
That last sketch is completely wrong for you.
ok, I forget the castle .ino then file
sorry for the time that you lose :unamused:
@francisrav4 what hardware do you use in your project?
usb cable and card arduino uno + smartphone in wifi
It’s all in the original post.
I have successfully when installed the blynk-local server, but when i started the bynk-ser.bat in blynk library i have error like this image http://prnt.sc/d2focg
In the batch file there is an option to switch off SSL (somewhere in the top of the file, it has comments). Can you try to switch to plain TCP? Sometimes it helps.
-edit
@arieiswadi your port is wrong in the batchfile. It should be 8441 or 8442 (non-SSL / SSL)
-edit more
If that also doesn’t work there is the option of using the same auth token on two devices, but that requires some planning ahead with pin names etc.
