Local server and mail
I was wondering if the Mail Widget also works with the local server? When I examine the logs of starting the server local I see "example@gmail.com" and the gmail smtp server. Is it possible to change those and use it via my local Blynk server?
I’ve been reading some of the FAQ and server documentation, but I can’t seem to find it. Thanks!
Congratulations! You are the first person who reached that point during local server setup =)! Added instruction to readme.
Haha, thank you!
I will try it when at home. I couldn’t get certificates to work so I’m (at the moment…) not able to open up the server to the world, so local mail facilities will do fine. Thanks again!
Just a little notice when using gmail smtp, you have to setup Gmail to allow less secured applications.
It may be worth noting this in the documentation @Dmitriy :slight_smile:
It was so many days ago that I don’t remember =). Do you know where those property in gmail settings?
Go here:
https://www.google.com/settings/security/lesssecureapps
And then click “Allow less secure apps”.
I didn’t really have to time to figure out the e-mail function for local server, but it appears to be working fine btw. My wife is starting her new fishtank, so I have to e-mail her when the temperature is off, lol.
Cool. Thank you for help! Doc. updated.
Hi, I don´t know how to Generate SSL certificates
I read this but I don´t know what to do
please help me
I’m using a Windows 7 machine
greetings
If you are using Google 2 Step Verification which you must do for certain Google apps, you must also follow this set up procedure
https://support.google.com/accounts/answer/185833
I have not tried this, only read about it as I followed this post.
