Local and Global Variables
I created slider in blynk and I want to get the slider value to outside variable (Not inside BLYNK_WRITE(Vx) )
How is it possible to get the variable out of the BLYNK_WRITE() and use it for global variable . When i define the variable global the value display always shows 0. Can anyone cmnt code with slider value assign to outside variable from BLYNK_WRITE()
Thanks for your help.
You are probably re-declaring the variable as local, by having an int Or float Command before your variable name within the BLYNK_WRITE function, but itโ€™s impossible to say with any certainty as you havenโ€™t bothered to share your sketch.
int m;
BLYNK_WRITE(V9)
  int n = param.asInt();
I want to assign โ€˜nโ€™ (Inside BLYNK_WRITE) value to โ€˜mโ€™ (Out side integer variable).
As I suspected, you are re-declaring m inside your BLYNK_WRITE function.
Change it toโ€ฆ
n = param.asInt();
and declare n as a global variable, not m
Thank you so much. It works!!!
