Load control using blynk with ESP8266 nodemcu and i2c display showing problem
I am using nodemcu based on esp8266. The program was completely fine without i2c lcd. But after adding the code for lcd it shows the error message "expected constructor, destructor, or type conversion before ‘;’ token " and indicates it happens on the user-defined function I created for lcd. I have checked some similar issues where people done mistakes with parenthesis. As far I checked I am ok with this issue. Could anyone say what’s wrong with my code?
//Blynk Home Automation with Physical Button and ON OFF State Feedback
#include <ESP8266mDNS.h>  // For OTA with ESP8266
#include <WiFiUdp.h>  // For OTA
#include <ArduinoOTA.h>  // For OTA
#include <Wire.h>
//I2C pins declaration
LiquidCrystal_I2C lcd(0x27, 16, 2);
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
int relay2State = LOW;
int pushButton2State = HIGH;
int relay3State = LOW;
int pushButton3State = HIGH;
int relay4State = LOW;
int pushButton4State = HIGH;
#define AUTH "-7lvAR8s-1ZiXC9AVyXs"  // You should get Auth Token in the Blynk App.
#define WIFI_SSID "IUBAT_Area"                   //Enter Wifi Name
#define WIFI_PASS "iubat123"                   //Enter wifi Password
#define SERVER "blynk-cloud.com "             // Comment-out if use Blynk hosted cloud service
#define PORT 8442
#define RELAY_PIN_1      12   //D6
#define RELAY_PIN_2      16   //D0
#define RELAY_PIN_3      13   //D7
#define RELAY_PIN_4      15   //D8
#define PUSH_BUTTON_1     2   //D4
#define PUSH_BUTTON_2    14   //D5
#define PUSH_BUTTON_3     0   //D3
#define PUSH_BUTTON_4     1   //TX
#define VPIN_BUTTON_1    V12
#define VPIN_BUTTON_2    V13
#define VPIN_BUTTON_3    V14
#define VPIN_BUTTON_4    V15
#define OTA_HOSTNAME "Home_Automation"
BLYNK_CONNECTED() {
  Blynk.syncVirtual(VPIN_BUTTON_1);
  Blynk.syncVirtual(VPIN_BUTTON_2);
   Blynk.syncVirtual(VPIN_BUTTON_3);
  Blynk.syncVirtual(VPIN_BUTTON_4);
  // Alternatively, you could override server state using:
 // Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
 // Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
 // Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
 // Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
  relay1State = param.asInt();
  digitalWrite(RELAY_PIN_1, relay1State);
  lcd1();
BLYNK_WRITE(VPIN_BUTTON_2) {
  relay2State = param.asInt();
  digitalWrite(RELAY_PIN_2, relay2State);
  lcd2();
BLYNK_WRITE(VPIN_BUTTON_3) {
  relay3State = param.asInt();
  digitalWrite(RELAY_PIN_3, relay3State);
  lcd3();
BLYNK_WRITE(VPIN_BUTTON_4) {
  relay4State = param.asInt();
  digitalWrite(RELAY_PIN_4, relay4State);
  lcd4();
  if (digitalRead(PUSH_BUTTON_1) == LOW) {
    // pushButton1State is used to avoid sequential toggles
    if (pushButton1State != LOW) {
      // Toggle Relay state
      relay1State = !relay1State;
      lcd1();
      // Update Button Widget
    pushButton1State = LOW;
  if (digitalRead(PUSH_BUTTON_2) == LOW) {
    // pushButton2State is used to avoid sequential toggles
    if (pushButton2State != LOW) {
      relay2State = !relay2State;
      lcd2();
    pushButton2State = LOW;
  if (digitalRead(PUSH_BUTTON_3) == LOW) {
    // pushButton3State is used to avoid sequential toggles
    if (pushButton3State != LOW) {
      relay3State = !relay3State;
      lcd3();
    pushButton3State = LOW;
  if (digitalRead(PUSH_BUTTON_4) == LOW) {
    // pushButton4State is used to avoid sequential toggles
    if (pushButton4State != LOW) {
      relay4State = !relay4State;
      lcd4();
    pushButton4State = LOW;
  Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS,"blynk-cloud.com", 8442);
  ArduinoOTA.setHostname(OTA_HOSTNAME);  // For OTA - Use your own device identifying name
  ArduinoOTA.begin();  // For OTA
  lcd.init();//Defining 16 columns and 2 rows of lcd display
  lcd.backlight();//To Power ON the back light
  lcd.setCursor(1,0);
  lcd.print("L1  L2  L3  L3");
  pinMode(RELAY_PIN_1, OUTPUT);
  pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
  lcd1();
  pinMode(RELAY_PIN_2, OUTPUT);
  pinMode(PUSH_BUTTON_2, INPUT_PULLUP);
  lcd2();
  pinMode(RELAY_PIN_3, OUTPUT);
  pinMode(PUSH_BUTTON_3, INPUT_PULLUP);
  lcd3();
  pinMode(RELAY_PIN_4, OUTPUT);
  pinMode(PUSH_BUTTON_4, INPUT_PULLUP);
  lcd4();
  // Setup a function to be called every 100 ms
  timer.setInterval(500L, checkPhysicalButton);
  ArduinoOTA.handle();  // For OTA
lcd1(){
  if(relay1State==HIGH){
  lcd.setCursor(1,1);
  lcd.print("ON ");
  if(relay1State==LOW){
  lcd.setCursor(1,1);
  lcd.print("OFF");
lcd2(){
  if(relay2State==HIGH){
  lcd.setCursor(5,1);
  lcd.print("ON ");
  if(relay2State==LOW){
  lcd.setCursor(5,1);
  lcd.print("OFF");
lcd3(){
  if(relay3State==HIGH){
  lcd.setCursor(9,1);
  lcd.print("ON ");
  if(relay3State==LOW){
  lcd.setCursor(9,1);
  lcd.print("OFF");
lcd4(){
  if(relay4State==HIGH){
  lcd.setCursor(13,1);
  lcd.print("ON ");
  if(relay4State==LOW){
  lcd.print("OFF");
You’re missing the word void before your function names.
:scream: Thanks dear.
