Hello there,
I’m trying to connect my Quectel M66 via Blynk. However, I could not find which library I should use suitable for this model. If any, I request your help.
Equipment
Arduino UNO
Quectel M66
Blynk
Hello there,
Equipment
Arduino UNO
Quectel M66
Blynk
When I make a transaction using the code below, I get the response connecting to blynk-cloud.com:8080…OK, but the device does not appear online in the blynk application.
http://twitter.com/blynk_app
Project setup in the Blynk app:
Value Display widget on V2
#include <GSM.h>
const char auth[] = "YourAuthToken";
// Blynk cloud server
const char* host = "blynk-cloud.com";
unsigned int port = 8080;
// Network settings
#define PINNUMBER ""
// APN data
#define GPRS_APN "GPRS_APN" // replace your GPRS APN
#define GPRS_LOGIN "login" // replace with your GPRS login
#define GPRS_PASSWORD "password" // replace with your GPRS password
GSMClient client;
GPRS gprs;
GSM gsmAccess;
// Start the GSM connection
void connectNetwork()
Serial.println("Connecting to GSM...");
bool status = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (status == false) {
if ((gsmAccess.begin(PINNUMBER) == GSM_READY) &
(gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)) {
status = true;
Serial.print(".");
Serial.println();
Serial.println("GSM connected");
bool httpRequest(const String& method,
const String& request,
String& response)
Serial.print(F("Connecting to "));
Serial.print(host);
Serial.print(":");
Serial.print(port);
Serial.print("... ");
if (client.connect(host, port)) {
Serial.println("OK");
Serial.println("failed");
return false;
client.print(method); client.println(F(" HTTP/1.1"));
client.print(F("Host: ")); client.println(host);
client.println(F("Connection: close"));
if (request.length()) {
client.println(F("Content-Type: application/json"));
client.print(F("Content-Length: ")); client.println(request.length());
client.println();
client.print(request);
client.println();
//Serial.println("Waiting response");
int timeout = millis() + 5000;
while (client.available() == 0) {
if (timeout - millis() < 0) {
Serial.println(">>> Client Timeout !");
client.stop();
return false;
//Serial.println("Reading response");
int contentLength = -1;
while (client.available()) {
String line = client.readStringUntil('\n');
line.trim();
line.toLowerCase();
if (line.startsWith("content-length:")) {
contentLength = line.substring(line.lastIndexOf(':') + 1).toInt();
} else if (line.length() == 0) {
break;
//Serial.println("Reading response body");
response = "";
response.reserve(contentLength + 1);
while (response.length() < contentLength && client.connected()) {
char c = client.read();
response += c;
client.stop();
return true;
Serial.println();
Serial.println();
connectNetwork();
String response;
unsigned long value = millis();
// Send value to the cloud
// similar to Blynk.virtualWrite()
Serial.print("Sending value: ");
Serial.println(value);
String putData = String("[\"") + value + "\"]";
if (httpRequest(String("PUT /") + auth + "/update/V2", putData, response)) {
if (response.length() != 0) {
Serial.print("WARNING: ");
Serial.println(response);
// Read the value back
// similar to Blynk.syncVirtual()
Serial.println("Reading value");
if (httpRequest(String("GET /") + auth + "/get/V2", "", response)) {
Serial.print("Value from server: ");
// Set Property
Serial.println("Setting property");
if (httpRequest(String("GET /") + auth + "/update/V2?label=" + value, "", response)) {
// For more HTTP API, see http://docs.blynkapi.apiary.io
// Wait
delay(30000L);
Which version are you using?
Editor: Arduino 1.8.15
Arduino UNO
I am waiting for your help please
